12 Replies Latest reply on Jul 25, 2013 6:07 AM by Peter Spier
    Anchored text box within a text frame
    lister110 Level 1
      I'm struggling to find the correct anchored option to allow an anchored text box to sit under a paragraph block with a 4pt space after. What I need is to edit the paragraph above. If the copy runs onto more lines I want the box to drop down as the extra line increase (to keep in the flow).
      Also, I may need to increase the amount of copy inside the anchored text box. When I pull the depth of the anchored box down, the whole anchored box shoots up. The space after the above paragraph has lost its spacing.
      Can anyone explain the best way to anchor a box which could change in depth but keep the same spacing between each block of text?
      lister
      Indesign CS6
      OSX
