3 Replies Latest reply on Jul 26, 2013 4:42 AM by try67
    How to access text selection attributes (bounding box) in a pdf
    GautierThomas57
      How can we access text selection attributes in a pdf (bounding box), when the selection is made with the findtext method under vba javascript?
      I'm currently looking for this attribute/method as I need to position buttons on specifics words in a pdf.
        • 1. Re: How to access text selection attributes (bounding box) in a pdf
          In JS this is done by using the getPageNthWordQuads method, which returns an array of quads that represents that specific word.
          • 2. Re: How to access text selection attributes (bounding box) in a pdf
            GautierThomas57 Level 1
            yes thanks a lot for the info: It works fine!
            But using this method I can't access my string using the Findtext method and thus have to use getPageNthWord and access word by word the pages wich is pretty time consumming. Do you have any idea to accelerate the scanning/parsing of my entire documents (~3000 pages).
            here after is the code used to position poup on my string String2Search
            Sub PdfTextExtraction()
                Dim pddoc As New AcroPDDoc
                Dim jso As Object
                Dim txt As String
                Dim cntPages As Long
                Dim cntWords As Long
                Dim quad As Variant
                Dim ip As Long
                Dim iw As Long
                Dim RefPath As String
                Dim DocName As String
                Dim StringCurrent As String
                'Dim AcroRect As CAcroRect
                Dim counter01 As Integer
                Dim popupRect(0 To 3) As Integer
                Dim oVarDescr As Object
                Dim avobj As Acrobat.AcroAVDoc
                Set avobj = CreateObject("AcroExch.AVDoc")
                'Load the PDF File
                RefPath = "C:\tmp\"
                DocName = "filedoc"
                counter01 = 0
            pddoc.Open (RefPath & DocName & ".pdf")
            Set avobj = pddoc.OpenAVDoc(DocName)
                    Set jso = pddoc.GetJSObject
                    cntPages = pddoc.GetNumPages
                    For ip = 0 To cntPages - 1
                        cntWords = jso.getPageNumWords(ip)
                        For iw = 0 To cntWords - 1
                        'get words
                        'StringCurrent = jso.getPageNthWord(ip, iw, True)
                        If jso.getPageNthWord(ip, iw, False) = "String2Search" Then
                            quad = jso.getPageNthWordQuads(ip, iw)(0)
                                    'Set popup
                                        popupRect(0) = CLng(quad(0)) 'Left
                                        popupRect(1) = CLng(quad(1)) 'Top
                                        popupRect(2) = CLng(quad(2)) 'Right
                                        popupRect(3) = CLng(quad(5)) 'bottom
                                        Set oVarDescr = jso.AddField("PopUpID" & counter01, "button", ip, popupRect)
                                        With oVarDescr
                                            .UserName = "This cal is to determine..."
                                        End With
                                        counter01 = counter01 + 1
                          End If
                        Next iw
                    Next ip
                Set jso = Nothing
                Set pddoc = Nothing
            End Sub
            • 3. Re: How to access text selection attributes (bounding box) in a pdf
              That's the only way of doing it with JS.
              On Fri, Jul 26, 2013 at 12:54 PM, GautierThomas57
