4 Replies Latest reply on Jul 26, 2013 10:20 AM by Trent Happel
    Import/export XAVC 4k content to PP7CC and so on
    drhdvideo
      1) How to import/export Sony XAVC 4k content ? There are sequence-presets for ARRI and RED but non for XAVC 10bit 4:2:2.
      2) How to change the frame-numbering to e.g. 8 digits whit JPEG or DPX export? 4 Digits = 3'20" movie-lenght only!
      3) DNxHD Export is availlable. Why not also ProRes on Mac sytems?
      4) How to sort clips in the icon-view up or down in the bin-window?
        • 1. Re: Import/export XAVC 4k content to PP7CC and so on
          Trent Happel Adobe Employee
          1) In CC, Sony XAVC is supported and should import like other supported formats. Export is not currently supported. You could try to export as DPX. To create a Sequence, grab a file in the Project panel and drop on the New Item icon (lower right of Project panel) to create a Sequencebased upon attributes of the file.
          2) When you export DPX, for the Output Name, name it to have whatever number of digits you would like. Eg: "MyExport 00000000"
          3) ProRes is available on Mac, if you have 10.8.x. Otherwise, if you have another application that installs ProRes, then it should also show up in Premiere Pro.
          4) Simply grab the file in the Project panel and drag it up or down to sort the file.
          I hope this helps.
          • 2. Re: Import/export XAVC 4k content to PP7CC and so on
            drhdvideo Level 1
            Hi Trent,
            thanks a lot for your answers.
            It seams, 4) was not clearly described. My F55 generates clips with names "Clip0000" to "Clipnnnn". In the list view, they are sorted  starting with 0000, but in the icon-view, there is a unlogical muddle. Of course I can sort them individualy by drag and drop but with some hundred clips???  FCP even in Rev.1 had a sort by name up/down command. Is that so difficult to implement also in PPCC?
            3) I use 10.8.4 but after Media > Export > Format, e.g. DNxHD is listed but not ProRes, even not in the Quicktime-Presets. Later in the Video-Codec window, ProRes is finally available. Why that hidden?
            1) Yes, I know this procedure but when I check the sequence attributes, the report is "AVC unlimited" what ever this means but no answer, if it's 10bit 422 as XAVC or regular 8bit 4:2:0 H264.
            With other words, XAVC is not very well implemented in PP CC.
            Best regards
            Toni Schweizer
            • 3. Re: Import/export XAVC 4k content to PP7CC and so on
              Jim_Simon Level 8
              The default for Icon sorting is the order of Import.  If you always import from first clip to last, they will show in sequential order.
              CC7 does now have automatic sorting in Icon view.  Just click the up/down arrows next to the mountain icon at the bottom of the panel.
              That's where it's always been.  As QuickTime can contain any number of codecs (just like AVI can), this is where that selection is made.
              • 4. Re: Import/export XAVC 4k content to PP7CC and so on
                As Jim mentions, there are additional options for sorting in the Sort Icons (bottom left of Project panel).
                Since native ProRes support is only available on 10.8, presets were not added. There are some available for download or you can create your own.
                Please feel free to submit requests for added XAVC support. https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
