9 Replies Latest reply: Aug 3, 2013 2:25 PM by fgregor RSS
    Dead links in CC Exchange Panel; in CS6 extensions don't install
    MPDAEF Community Member
      Extension mgr CC is installed; Exchange extension is enabled.  BUT, in PS CC, the exhange panel links are dead (the panel opens but doesn't seem live).  In PS CS6, the previous extensions are fine, but no new ones will install, though they seem to download.  The only error message I get in CS6 is that the installation failed and I should close Exchange and try again.  That doesn't help.  I get no error message in CC.
      Does anyone have a suggestion?  I've posed a similar question elsewhere but received no answers thus far.
      (Running Windows 7, 64-bit)
        • 1. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
          lesavage Adobe Employee
          Hello,
          A couple of questions to help determine what is going wrong:
          1) what versions of extension manager CC and CS6 do you have installed?
          2) what version of the panel do you have installed? For CC you can check this by going to program files/common files/adobe/CEPServiceManager4/extensions/adobeexchange/csxs/manifest.xml. In CS6 go to the common files directory but look in CS6ServiceManager directory instead. I would expect both panels to have a version of 1.0.0
          3) when you say the links are dead, what links? The tabs, product info or the download links?
          Thanks in advance,
          Lea
          • 2. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
            Hi, Lea,
            Thanks for responding.  Yes, both panels seem to be version 1.0.   The
            extension manager is the one I just (today) downloaded from the CC
            downloads site.  I had been having download/update problems, so this
            morning I uninstalled and cc-cleaned all the CC apps, including desktop
            link, and reinstalled the four or so that I use.  This didn't change the
            behavior of the Exchange panels in either version.  Everything else seems
            to be working normally.
            If the web site isn't misleading, shouldn't the new CC extension manager
            replace the CS6 one and work for both programs?  I do still have the CS6
            ext mgr in my program list, but clicking it doesn't open anything,  Neither
            does the exe file in the file location for the CS6 ext mgr.  Should I be
            deleting these manually?  I don't want to destroy any CS6 software that I
            can't replace.
            As to what doesn't work in CC Exchange:  when the panel opens, it becomes
            white and then changes to the black welcome panel, saying that there's an
            available update in PS.  (There isn't; PS CC is up to date.)  Nothing in
            that welcome panel is live except for the little menu at upper right that
            has links to launch or install ext. mgr or access help, etc. The other
            items in the pre-installed Extensions (Kuler, Mini-Bridge) seem fine.
            In CS6, Exchange panel opens normally and connects to the extensions I
            already have.  The tabs are live, as are the download links.  BUT, a
            selected extension will download but never complete installing.
            Eventually, the "moving circle" stops, and I get a "try again" message.
            Sounds to me as though there's a corruption somewhere in the CS6 version.
            What do you think?
            Gail
            • 3. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
              Hi Gail,
              When working in CS6 you require CS6 Extension Manager.
              When working in CC you require CC Extension Manager but this is optional. When Extension Manager CC is required the panel will prompt you to download the latest version from the CC desktop client.
              FYI, if you ever need to reinstall a CS6 point product then in creative.adobe.com, you can choose CS6 from a drop down menu:
              In terms of CS6, it sounds like your Extension Manager CS6 could be corrupted considering it will not let you launch the application. I would recommend uninstalling Extension Manager CS6 and downloading it again from http://www.adobe.com/exchange/em_download/em6_download.html
              In terms of CC, can you confirm that the manifest file shows the following as I would not expect you to see the update message if you had the 1.0.0 panel installed.
              ExtensionBundleVersion="1.0.0"
              I look forward to hearing from you,
              Lea
              • 4. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
                I do appreciate your help.  Your suggestions make sense entirely, but the
                problems have multiplied.  Unfortunately, I'm going to have to call
                Customer Service, and spend the necessary hours! to get this fixed.
                I did uninstall (and cleaner tool) Ext Mgr CS6, but it won't re-install.
                (Installer says to use the Support Advisor, which says to use the cleaner
                tool to remove the Ext MrgEXCEPT it is no longer on the Cleaner listor
                anywhere else in my computer that I can find.)   Also, while all the CC
                apps I un- and re-installed yesterday are working, the two big ones failed
                to do their updates last evening.  I have tried to find and work with the
                error codes, but the instructions and links are either not to be found or
                not workable.  (I.e., the error codes--and the tech notes about
                them--aren't to be found through any of the links Adobe provides in its
                help or search instructions.  I'm sure they are there somewhere, but Adobe
                doesn't make it possible, for me at least, to find them.)
                Again, thank you.  I'm a little frustrated with Adobe.  I spent about 30
                hours earlier this year with Adobe tech support in order to solve a problem
                that was, finally, entirely the fault of an Adobe server.  So you can see
                why I'm not eager to make that phone call.
                Gail
                • 5. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
                  fgregor Adobe Employee
                  Hi Gail,
                  Sorry to hear you're still having problems. While CC product updates failing to install is not something we can personally help with, for problems with Adobe Exchange and Extension Manager I think that these forums are probably the most appropriate place to get help. Adobe Exchange is a relatively new service that is changing quickly, and engineers from the Adobe Exchange and Extension Manager teams check these forums on a daily basis. Lea and I are engineers working on Adobe Exchange (including the servers) so we may be able to work out what the problem is without you needing to call tech support.
                  Note that you can download the cleaner tool here:
                  http://www.adobe.com/support/contact/cscleanertool.html
                  If you're struggling to install Extension Manager CS6 after having uninstalled it, can you check for the following folders and move them to your Recycle Bin them if they exist?
                  C:\Users\<username\AppData\Roaming\Adobe\Extension Manager CS6
                  C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6
                  After then downloading and installing Extension Manager CS6 from the link Lea shared,
                  ...if you still get an error code, please let us know which code it is so that we can find out what it means.
                  By the way, you said that you don't want to "destroy" any CS6 software you can't replace - but if you do need to ever re-download/install CS6 products, you can always get CS6 versions from https://creative.adobe.com/products as a Creative Cloud member.
                  Hope this helps you to get a little further.
                  Best wishes,
                  Fraser
                  • 6. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
                    Ok.  I followed your suggestions.  I also found in the AppData an Extension
                    Manager 7.0 (no indication of CC or CS) and deleted it, too.  I assume this
                    was ok to do.
                    It took some time and fiddling to extract and install, but that seems to
                    have worked.  I believe the Ext Mgr works, but it gets hung up trying to
                    download extensions.  That is, when I open it, it gets about 2/3 across the
                    "loading extensions" bar and then freezes (I have to use task mgr to close
                    it).
                    I think it's Adobe Exchange that may be the problem.  In PS CS6, the items
                    already in the ext. mgr seem to work (e.g., Kuler, Paper Texture Pro), but
                    the Exchange extension itself opens only a black panel and doesn't respond
                    in any way. (See below for more info.)
                    In PS CC, the Kuler and Mini Bridge extension work normally, I think, but
                    the Exchange panel opens (blank) and can't be closed until an error message
                    appears that the command couldn't be completed because "the extension could
                    not be loaded."
                    When the CS6 Ext Mgr gets hung up, and the Task Mgr is used to close it,
                    the Tsk Mgr offers the following details.  Maybe they'll be helpful.  I'd
                    be most grateful if you could solve this Exchange problem, so I'd have to
                    be concerned only with failed updates, which I'm sure are fairly common
                    these days.
                    Problem signature:
                      Problem Event Name:    AppHangB1
                      Application Name:    Adobe Extension Manager CS6.exe
                      Application Version:    6.0.7.0
                      Application Timestamp:    51e3622d
                      Hang Signature:    dd44
                      Hang Type:    6144
                      OS Version:    6.1.7601.2.1.0.256.48
                      Locale ID:    1033
                      Additional Hang Signature 1:    dd44f1ebbff1fe5ee45288b3764bd45d
                      Additional Hang Signature 2:    b388
                      Additional Hang Signature 3:    b38839b95fa5ad913a4739800c351dec
                      Additional Hang Signature 4:    dd44
                      Additional Hang Signature 5:    dd44f1ebbff1fe5ee45288b3764bd45d
                      Additional Hang Signature 6:    b388
                      Additional Hang Signature 7:    b38839b95fa5ad913a4739800c351dec
                    Many thanks.
                    Gail
                    • 7. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
                      Hi Gail,
                      Could you send the following information to me at lesavage at adobe dot com.
                      - Screenshot of what the Exchange Panel looks like in CS6 when loaded, e.g. a screenshot of the blank panel
                      - Send the above error report so I can forward it onto the Extension Manager team
                      - Can you enable the Extension Manager CS6 logs as outlined at http://forums.adobe.com/message/4275082#4275082 so I can forward them onto the Extension Manager team to determine why the application is hanging.
                      - Adobe Exchange log which is located at: C:\Documents and Settings\<user>\AppData\Roaming\Adobe\Exchange\AdobeExchange.log
                      Thanks in advance,
                      Lea
                      • 8. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
                        Hi, fgregor,
                        I have finally gotten the original problems solved (as of Aug 2), but I'd like to comment on your "you can always get CS6 versions" as a CC member.  I've been to the link, which takes one to downloads page, and I don't see any way of downloading a CS6 app.  I've been looking to replace Muse CS6, and all that's offered is Muse CC.  I checked one or two other apps as well, in case this is a Muse situation only.  What am I missing?
                        Gail
                        • 9. Re: Dead links in CC Exchange Panel; in CS6 extensions don't install
                          Hi Gail,
                          Glad to hear your original problems are now solved - thanks for letting us know.
                          As for downloading CS6 apps - the reason you can't get an older version of Muse through the Creative Cloud website is probably that Muse was not released with CS6 - see http://www.adobe.com/uk/products/cs6/faq.html for a list of what was included with CS6.
                          You can get apps which were part of CS6 by going to their product page, and then selecting the CS6 version from the dropdown just under "In this version":
                          Hope this helps.
                          Fraser
