2 Replies Latest reply on Jul 25, 2013 9:07 PM by JJMack
    Why does Image Processor give wrong results ?
    accafella12
      Hello.
      I was trying to resize some images to 1080 x 1920 (tiff) using Image Processor but the resulting images came out as 1080 x 1620 and the filesize appears to have remained unchanged. Similarly, another time 720 x 576 came out as 720 x 540.
      Have i missed something ? Can someone please help, i'm baffled.
      Thanks.
        • 1. Re: Why does Image Processor give wrong results ?
          Level 5
          That's perfectly normal and expected behavior.
          Quite simply your images do not have the necessary aspect ratio to fill the entire pixel dimensions you're specifying.  It's elementary, grade-school math.
          Your images are not tall enough in the specific cases you mention.
          Work out the ratio between 1080 and 1920:  you'll get an aspect ratio of 1:1.77777777777778.  That is exactly the aspect ratio to which you must crop your images first if you absolutely want those exact pixel dimensions (width x height).
          Other than that, the image processor is working exactly as it should.
          You can't fit a round peg into a square hole, so to speak.
          • 2. Re: Why does Image Processor give wrong results ?
            The Image Processor Scripts use Adobe Fit Image plug-in to do the resize. It looks like you trying to resize to fit a HDTV.  You should set width 1920 and the height to 1080.  All image will be re-size to fit within that size pixel area.  The image will retain their current Aspect Ratio  and not distort.  Image with a 16:9 aspect ratio will be resized 1920 px wide and 1080 px high.  Image with an Aspect ratio wider then 16:9 will be resize 1920 PX  width and x PX high where x is less then <1080. If an images aspect ratio is narrower then 16:9 the image will be resized x PX wide and 1080P X high where x is less the <1920.
