• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
IMPORTING FLASH FILE IN CAPTIVATE
New Here ,
Jul 26, 2013 Jul 26, 2013
Hi!
I have an interactive training module created with Flash. It has buttons, videos, and quizzes.
Now, to make it compatible with SCORM. I was advised to use Captivate.
Is it possible to export the whole flash file in Captivate? Please help.
Thank you very much!
TOPICS
Import export
Views
1.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
If this was all developed in Flash then the best bet is to use the Pipwerks SCORM wrapper to make your Flash file compatible.
More info here: http://pipwerks.com/
You may be able to insert your Flash file as an animation into Captivate, but this won't make it SCORM compatible.  You might be able to recode the Flash file as an interactive widget and make it have a Success result when the user passes the module.  Then when you insert it into Captivate you can set the interactive widget to have a score.
More information about coding widgets can be found here:
http://www.infosemantics.com.au/widgetfactory/info
Votes
Translate
Translate
Report
Report
New Here ,
Thanks RodWard for the fast response!
We were able to convert the flash file to SCORM 1.2 and 2004. But it's  looking for lmsmanifest.xml file to make it compatible.
In which program can we create this lmsmanifest.xml file?
Votes
Translate
Translate
Report
Report
Community Expert ,
Notepad.  It's an xml text file.
Look on the Scorm.com site for info about the syntax.
Votes
Translate
Translate
Report
Report
New Here ,
Thank you so much! Appreciating your fast response.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Log into the Adobe website with your Adobe ID.  Go to the page where you can download the trial version of Captivate 7.  There you will also find links to download the voices for Cp7.
Votes
Translate
Translate
Report
Report
Resources
Help resources
