1 Reply Latest reply on Aug 6, 2013 12:36 AM by Phogelius
    Custom OSMF source with mxmlc compiler
    Phogelius Level 1
      Hello all,
      I am trying to compile my FB 4.7 project with mxmlc via the command line tool.
      It works fine in FB but when I am using the command line I get errors. It says I have duplicate OSMF sources in my project. One is the standard from the library in /usr/local/flex_sdk_4.6/frameworks/libs/osmf.swc - but I don't want to use that, instead I made a custom (with these changes: http://forums.adobe.com/message/5180482 ) and the classes for that are in my project's "src" folder.
      The compiler doesn't know which to use and can't resolve, end result is the compilation failing.
      Is there a command or something alike to tell the compiler that the swc inside /usr/local/flex_sdk_4.6/frameworks/libs should be ignored? I can't just delete the osmf.swc because I need it as it is in other projects.
        • 1. Re: Custom OSMF source with mxmlc compiler
          Phogelius Level 1
          Uh, nevermind. Found out myself. In the compiler options I manually add the swcs I want to use:
          -library-path=PATH_TO_SDK/frameworks/libs/core.swc
          -library-path+=PATH_TO_SDK/frameworks/libs/framework.swc
          -library-path+=PATH_TO_SDK/frameworks/libs/spark.swc
          -library-path+=PATH_TO_SDK/frameworks/libs/rpc.swc
          -library-path+=PATH_TO_SDK/frameworks/locale/en_US/
          -static-link-runtime-shared-libraries=true
          With this only the OSMF sources in my src folder are used and the project compiles.
          Notice how in the first line I am using "library-path=" to overwrite the default path and then add the other required libraries by using "library-path+="
