2 Replies Latest reply on Jul 28, 2013 12:14 PM by artCraft2
    Find indesign doc Path and continue next
    artCraft2
      Hi Forum,
      I have a small thing to function over...
      I want to check if the indesign document is saved inside the path "/INDD_Jobs" and then proceed checking color Else alert and exit..
      IndFol=Folder(("/Volumes/artCraft/Livejobs/Dingy/"+[here the folder name varies]+"/INDD_Jobs").parent);
      eg.
      IndFol=Folder(("/Volumes/artCraft/Livejobs/Dingy/"+123+"/INDD_Jobs").parent); // highlighted blue is the place where indesign doc is stored.
      IndFol=Folder(("/Volumes/artCraft/Livejobs/Dingy/"+456+"/INDD_Jobs").parent); //highlighted red is the folder before INDD folder which will vary.
      var mDoc = app.activeDocument;
      ky = IndFol.path + "/" + IndFol.name;
          currentPath = mDoc.filePath;
          if(currentPath ==ky.filePath)
      do something.............
      else{
      alert ("WARNING:" + "\r" + "FILE SAVED IN WRONG LOCATION" + "\r" +  mDoc.filePath.fsName +"\r" + "\r" +"\r" +"SAVE TO" + "\r" +IndFol.filePath), exit();
      Please help me to do this...
        • 1. Re: Find indesign doc Path and continue next
          artCraft2 Level 1
          Hi Forum
          Because often I use to work on destop or downloads, i forget to save on a particular path...
          So the alert is needed to convey the document is not in path.
          atleat if it could check the path up to here, is ok
          thanks forum..
          • 2. Re: Find indesign doc Path and continue next
            artCraft2 Level 1
            Hi Forum,
            Could i able to find document path like this..
            eg. if myfile path is.
            "~D:\artCraft\Livejobs\01/23/23344\Dingy\" (pc machine)
            can we compare file path using any alphabets and any digits.
            var letterNumber = "^~[0-9a-zA-Z]:\\[0-9a-zA-Z]+$\\"+"\\^[0-9a-zA-Z]+$\\" + "\\^[0-9a-zA-Z]+$\\"+ "\\^[0-9a-zA-Z]+$\\";
            var path = app.activeDocument.filePath +"\\" + app.activeDocument.name;
            if((path == letterNumber))
            alert ("found path")
            Please help....
