2 Replies Latest reply on Jul 26, 2013 5:34 AM by rajnikids
    Export PDF to path
      Hi everybody,
      I do have a challenge in exporting PDF to particular folder called "PDF".
      The PDF path to be exported inside the folder News/PDF/. //PDf file path.
      where indesign file will be inside News/File1/untitled.indd. //indesign File path
      The ESTK shows the error result... as "Cant find the folder".
      var myFolderPDF = Folder(app.activeDocument.filePath).parent + "/PDF/"
      var myJobOptionName = "Paper"; //Please provide a PDF job option name which is available in InDesign.
      var myOutFolderPathName = Folder(app.activeDocument.filePath).parent + "/PDF/"; //Please change your path as per requirement
      var myPDFFilePath=myOutFolderPathName;
      var InDJobOption = app.pdfExportPresets;
      app.documents[0].exportFile (ExportFormat.pdfType, myPDFFilePath, false, myJobOptionName);
      thanks forum
        • 1. Re: Export PDF to path
          rajnikids Level 1
          Also used this script from Forum..
          var myFolderName = myDoc.filePath;
          var myDocumentName =  myDoc.name.slice (0, -5);
          var myFilePath = myFolderName + "/" + myDocumentName + ".pdf";
          var myFile = new File(myFilePath);
          var myF = Folder(myFile.parent+"/") +"/PDF/"  // here pdf should be saved inside the folder "PDF".
          myDoc.exportFile(ExportFormat.pdfType, myF, false, "Press Quality");
          • 2. Re: Export PDF to path
            rajnikids Level 1
            Thanks I found it...
            var myFolder = app.activeDocument.filePath.parent + "/PDF/";
            var myDocname = myDoc.name.split(".indd");
            myDoc.exportFile(ExportFormat.PDF_TYPE, File(new File(myFolder+"/" + myDocname.join(".pdf"))));
