I have jQuery DatePicker and TimePicker which works in the form.
jQuery DatePicker and TimePicker do not show in CFWINDOW.
I did Google and see some discussion, but no luck,
I would like to know any work around to have make jQuery DatePicker and TimePicker works in CFWINDOW,
Your help and information is great appreciated,
Regards,
Iccsi,
Did you take a look the examples on the web site? You can also create a form inside the dialog.
http://jqueryui.com/dialog/#modal-form
Anyway, if I were I would not use any built-in UI related tags from ColdFusion. I have had bitter experience such as slow performance and lack of compatibility between CF versions. The later one would cause more works in the future.
Good luck!
Why don't you use jQuery Dialog to achieve the same thing instead of using cfwindow?
Thanks for the information and help,
Dialog is a good idea to show some informaiton or message to the users.
I need to use CFWINDOW, because I have contorls on the form like DatePicker, TimePicker, Select to let user enter information,
Thanks again for helping,
Regards,
Iccsi,
Good luck!
Thanks a million for helping and information,
Regards,
iccsi,
