3 Replies Latest reply on Jul 26, 2013 2:57 PM by CarlosCanto
    Inversing A Gradient
    Prails.deisgn Level 1
      Hey Guys,
      I'm trying to inverse all gradients within a document using Javascript
      I can't find the property to call to inverse them in any of the PDF's I have, and I'm having trouble calling gradients in general I can't even rename them at the moment.
      Any ideas?
        • 1. Re: Inversing A Gradient
          Here's an example of what i'm trying to do, I still can't specifically target just a gradient, I can only target paths as a whole.
          #target Illustrator
          //  Hopefully this controls Gradients
          var doc = app.activeDocument;
          idPaths(doc)
          //Inverses Gradient direction
          function idPaths(doc){
              for(i=0;doc.pathItems.length>i;i++){
                  doc.pathItems.gradients = true;
                  doc.pathItems.inverse = true;
                  doc.pathItems[i].name= 'Superman '+(i+1)
          // Still doesn't work ...
          // function idSad(user) = true
          • 2. Re: Inversing A Gradient
            Found a workable solution but it requires the user to select the gradient, and it only does one at a time, so getting closer but not there.
            Found this script here on the foum:
            http://forums.adobe.com/message/5047864#5047864
            #target Illustrator
            // GradientBlackWhite_rotated.jsx
            // requires an open document and one selected object
            var newGradient = app.activeDocument.gradients.add();
            var colorOfGradient = new GradientColor();
            var myGradientAngle = 180;
            colorOfGradient.gradient = newGradient;
            doc.selection[0].fillColor = colorOfGradient;
            /*Thanx to John Wundes for this -->*/doc.selection[0].rotate(myGradientAngle, false, false, true, false, Transformation.CENTER);
            redraw();
            //alert("Flipped!");
            • 3. Re: Inversing A Gradient
              CarlosCanto Adobe Community Professional & MVP
              dude, are you writing your own properties? you have to go to the OMV or the Reference and use what's available, gradients and inverse do not exist.
