3 Replies Latest reply on Jul 30, 2013 12:01 AM by GuanshuaiQiao
    Repeated name and address fields.
    PWGTCLAW
      I have four combined forms sent as a single form to clients. All four forms need to comply to a standard format.
      Once the client has completed and submitted these forms, they are separated and sent to various parties.
      Each of the four forms need to contain name, email and adress fields. Is there a way for a single entry in these fields to populate the subsequent fields that ask the same question?
        • 1. Re: Repeated name and address fields.
          GuanshuaiQiao Level 1
          In your case, would you like to entry different name or email , and ask same questions? If yes, We have a “multiple choices and skip logic rules” features, which may help you to design your form. This feature let you show or hide certain parts of items, or navigate to another part of the form based on how the user answers certain questions.  Here’s an example, when you select question 1 and 2, showing the three fields,Email, name, address. Or you can duplicate these fields for different name and email.
          Guanshuai
          • 2. Re: Repeated name and address fields.
            PWGTCLAW Level 1
            Guanshuai
            Thanks for your suggestion; I need the data from, say, question1 "Your Name" to appear when the same question is asked in question2. In other words we ask the same question twice and the same answer should appear twice (in a different part of the form) so that the form-filler does not need to put their name in twice.
            • 3. Re: Repeated name and address fields.
              Please feel free to set any one or two questions as conditions, as long as the conditions are met to show items. Take your case as an example: you can add two single choice fields, put the same questions, then set these two questions as conditions to show your name. whatever form filler select any questions, name is only need to be input once. but it means that answer (name) is only showing once.
              Guanshuai
