1 Reply Latest reply on Jun 13, 2006 7:47 AM by ur_dtrain
    Package Compiler Issues
    firdosh Level 1
      Hey
      I am trying to compile a simple as3 file
      [code]
      package {
      import flash.display.MovieClip;
      class Test extends MovieClip{
      public function Test(){
      trace("Hello");
      [/code]
      It compiles ( with a warning) but I get this runtime error
      TextReferenceError: Error #1065: Variable Test is not defined.
      The compile time warning was
      C:\Applications\AS3Examples\Test\tst\Test.as(5): col: 8 Warning: class 'Test' will be scoped to the default namespace: internal
      So I decided to create a package
      I created a directory tst and put the class Test.as in that directory
      [code]
      package tst{
      trace("Hello");
      [/code]
      Now I try to compile using mxmlc
      mxmlc actionscript-classpath tst\ Test.as
      I get this
      Loading configuration file C:\Applications\Flex_sdk_2_0_beta3\frameworks\flex-config.xml, root element flex-config
      Error: unable to open 'Test.as'
      Can someone point out where I am going wrong ??
      thanks
      cheers :)
      firdosh
