6 Replies Latest reply on Jul 29, 2013 10:14 AM by A.T. Romano
    File formate
    dacecilie
      There were no results for How do I save my movie as a 4fv in the correct size 1920x1080, it keeps cropping my movie?
        • 1. Re: File formate
          A.T. Romano Level 7
          dacecilie
          What version of Premiere Elements are you using and on what computer operating system is it running?
          Assuming that you are using Premiere Elements 11 Windows
          What is your project preset?
          What are the properties of your source media on the TImeline?
          And, of immediate focus, what are you setting for your export....
          Publish+Share
          Computer
          Adobe Flash Video
          with Presets = F4V - HD 1080p (Flash 9 and Higher)
          or
          Something else?
          Are you aware of the Advanced Button for each preset. You can customize the export settings under Advanced Button/Video Tab and Audio Tab and any other Tabs there.
          Please review the above and then we can decide what next.
          Thank you.
          ATR
          • 2. Re: File formate
            dacecilie Level 1
            I am using a MacBookPro OS X 10.7.3 and Elements 11
            What is your project preset? Default
            Not sure
            Publish+Share
            Computer
            Adobe Flash Video
            Yes this is what I used
            When I go to advanced and un click resize video, I get a massage that 1920x1080 unsupported frame size
            • 3. Re: File formate
              A.T. Romano Level 7
              dacecilie
              You definitely do not want to leave "Resize Video" unchecked. Its description includes:
              "Select to change the output frame size. If you unchecked, the output frame size is determined based on source properties."
              This export choice is set for 1920 x 1080 and you want 1920 x 1080, so leave the Resize Video with check mark.
              You should be able to use the default settings and not get the problem that you describe. But, if you changed anything under the Advanced Button, Video Tab...have Profile = High and Level = 5.1.
              But let us look into your source on the Timeline and how the project is set up...
              First, if you go to Edit Menu/Project Settings/General, what do you see for Editing Mode, Timebase, and Frame Size?
              Second, if you right click you source's thumbnail in Project Assets and select Properties, what do you see for Frame Size and Frame Rate?
              Let us see how we do with the above requested information. If necessary, we can go after a properties readout for your source on the Timeline using a free program such a MediaInfo.
              http://mediaarea.net/en/MediaInfo
              Thanks.
              ATR
              • 4. Re: File formate
                dacecilie Level 1
                Hi
                Editing Mode it is grayed out but it says AVCHD 1080 sp Timebase it is grayed out but it says, 59,94 Frame Size 1920x1080
                Properties 1920x1080 Rate 59,94
                • 5. Re: File formate
                  A.T. Romano Level 7
                  dacecile
                  What are you using to view the .f4v file that is produced from your source 1080p60 file and 1080p60 project.
                  I think that I am seeing what you are describing when I use your settings and view the exported .f4v via VLC Media Player and QuickTime.
                  I have found one workaround and am in the process of confirming.
                  Coming soon.
                  ATR
                  • 6. Re: File formate
                    A.T. Romano Level 7
                    dacecilie
                    Please take a look at the following and let us know if this worked around the issue that you presented.
                    No need to change your 1080p60 project preset that was set for your 1080p60 source.
                    However, the export area is going to need a change of frame rate in the Export Settings dialog under the Advanced Button/Video Tab of the preset. So,
                    Publish+Share
                    Computer
                    Adobe Flash Video
                    Advanced Button
                    Video Tab
                    DO NOT USE SAME AS SOURCE
                    There is no 59.94 frames per second choice
                    Select the choice of 29.97 frames per second
                    That seemed to work for playback of this export in VLC Media Player, QuickTime Player. and Internet Explorer.
                    Thanks.
                    ATR
