I cannot pass an argument to a ColdFusion 10 web service if it's greater than approximately 5 KB, regardless of the data type. If I do, the browser returns with a "This page cannot be displayed" message (in IE) or "Server not found" (in Firefox). If I pass data to the same argument and it's < 5 KB, then it works perfectly fine. Is there a setting somewhere in ColdFusion, IIS or elsewhere that's causing this that I can adjust? I'm new to ColdFusion 10 and have never run into this with previous CF versions. I'm running Windows Server 2008 R2 Standard - 64 bit- IIS 7.5. Thanks.
Find and increase these variables in IIS: maxRequestEntityAllowed and uploadReadAheadSize
I had a similar issue a while back due to these settings. They control data to and from ISAPI connections (of which CF is one) according to this article:
http://www.iis.net/configreference/system.webserver/serverruntime
Sorry, I cant recall off hand where exactly those settings are in IIS but a quick Google search should turn it up for you.
I managed to find those settings in IIS under Configuration Editor. maxRequestEntityAllowed was already set to the maximum value at 4294967295 - and uploadReadAheadSize was set to the default - but I boosted it to the max setting at 2147483647. Unfortunately, it's still not working.
