7 Replies Latest reply on Jul 30, 2013 7:55 PM by PMK3
    Correct conversion process for 23.98 clips into 25 seq
    philc452 Level 1
      What is the correct process to convert sources of different frame rates to play correctly in seq? We have a couple different deliverables. Final files will be converted to mpeg2 either thru AME or thru seprate Telestream Episode Encoder
      Option 1:
      Final output is 25fps file - HD
      sources at 23.98 and 29.97 - seq at 25
      Option 2:
      Final output is 25fps file - SD PAL
      Both options need to maintain syc with attached audio, and maintain source duration
      We are always needing to convert frame rates....another example: 23.98 into 29.97 seq maintain audio sync and source duration.
      What about image seqs?
