1 Reply Latest reply: Sep 5, 2013 12:11 PM by RyanSchauer RSS
    Using mms.cfg In The Enterprise
    Jason-AU Community Member
      Hello, I’m currently investigating the best ways to install Flash Player in our corporate environment I’ve competed the request for enterprise downloads and I now have the access to the EXE & MSI installs.
      Briefly reading the Administration guide I now know that I can use mms.cfg to disable updates a requirement in our network due to the lack of admin rights.
      We will manage updates and fresh installs with SCCM 2012
      I want to be able to install Flash Player during OSD (Operating System Deployment) and also on existing machines what are the best proven methods of delivering the custom mms.cfg ?
      Can this be done with the command line if I use the EXE Bootstrapper install and not the MSI?
      Or do I have to look at using group policy or a script to deliver this file outside of the installation
      For Adobe reader I’m currently using the bootstrapper to install reader 11 and the latest MSP at the same time I’d like to do something similar for my Flash Player installs
        • 1. Re: Using mms.cfg In The Enterprise
          RyanSchauer
          My solution was as follows:
          1. In SCCM 2012, I created an application for flash player based on the MSI deployment.
          2. Created a second deployment type that executes a .CMD file with the following batch code in it (set dependency pointing to the Flash MSI completing successfully as well):
          • REM In case folders don't exist, create them
            MD %WINDIR%\System32\Macromed\Flash
            MD %WINDIR%\SysWow64\Macromed\Flash
          • REM Delete existing completion files
            Del %WINDIR%\System32\Macromed\Flash\Complete.flag
            Del %WINDIR%\SysWow64\Macromed\Flash\Complete.flag
          • REM Copy System32 CFG file and then copy the complete flag
            Copy /y %~dp0mms.cfg %WINDIR%\System32\Macromed\Flash
            Copy /y %~dp0Complete.flag %WINDIR%\System32\Macromed\Flash
          • REM Copy SysWow64 CFG file and then copy the complete flag
            Copy /y %~dp0mms.cfg %WINDIR%\SysWow64\Macromed\Flash
            Copy /y %~dp0Complete.flag %WINDIR%\SysWow64\Macromed\Flash
          Note: Completion.flag is merely a text file that gives me an easy way to know if the script finished running or not. I check for it's existence in both locations to consider the process complete.
          This has worked for me. The only hangup I had was that I set the MSI verification on the filename of the OCX that the installer puts in the System32 and SysWow64 folders not realizing that the filename is backwards from what I expected. System32 has the "Flash64..." file and SysWow64 has the "Flash32..." file. Goofy, I know.
          Hope this helps.
