8 Replies Latest reply on Sep 26, 2018 8:57 PM by danielfeary
    Break text area into text lines
    hilukasz Level 1
      I want to break text area with line breaks in it into seperate text lines using return as delineator. for example
      "Line 1
      Line 2
      Line 3"
      I would like as
      "Line 1"
      "Line 2"
      "Line 3"
      I could probably write something but curious if someone already wrote it. I found a few similar ones like
      http://forums.adobe.com/thread/321610
      but they seem to be broken for CC here is the script in case you're curious
      //Divide TextFrame v.2.2 -- CS and up
      // Divides a multiline text field into separate textFrame objects.
      // Basically, each line in the selected text object
      // becomes it's own textFrame. Vertical Spacing of each new line is based on leading.
      // This is the opposite of my "Join TextFrames" scripts which
      // takes multiple lines and stitchs them back together into the same object.
      // New in 2.1 now right and center justification is kept.
      // New in 2.2 better error checking, and now will run on more than one text frame at a time.
      // JS code (c) copyright: John Wundes ( john@wundes.com ) www.wundes.com
      //copyright full text here:  http://www.wundes.com/js4ai/copyright.txt
      var doc = activeDocument;
      var genError= "DivideTextFrame must be run on a point-text text-frame. ";
      var ret_re = new RegExp("/[\x03]|[\f]|[\r\n]|[\r]|[\n]|[,]/");
      if(doc){
              var docsel = doc.selection;
              var sel = [];
          //remember initial selection set
               for(var itemCt=0, len = docsel.length ;itemCt<len;itemCt++){
                   if(docsel[itemCt].typename == "TextFrame"){
                        sel.push(docsel[itemCt]);
              if(sel.length){  //alert(sel.length+" items found.");
                  for(var itemCt=0, len = sel.length ;itemCt<len;itemCt++){
                      divide(sel[itemCt]);
              }else{
                      alert(genError +"Please select a Text-Frame object. (Try ungrouping.)");
      }else{
          alert(genError + "No document found.");
      function divide(item){
                //get object position
          var selWidth = item.width;
      if(item.contents.indexOf("\n") != -1){
                //alert("This IS already a single line object!");
      }else{
          //getObject justification
          var justification = item.story.textRange.justification;
                //make array
                var lineArr = fieldToArray(item);
                tfTop = item.top;
                tfLeft = item.left;
                item.contents = lineArr[0];
                //for each array item, create a new text line
                var tr = item.story.textRange;
                var vSpacing = tr.leading;
          var newTF;
                for(j=1 ; j<lineArr.length ; j++){
                          newTF = item.duplicate(doc, ElementPlacement.PLACEATBEGINNING);
                          newTF.contents = lineArr[j];
                          newTF.top = tfTop - (vSpacing*j);
              if(justification == Justification.CENTER)
                   newTF.left = (tfLeft + (selWidth/2)) - (newTF.width/2);
          else
                  if(justification == Justification.RIGHT)
                  newTF.left = (tfLeft + selWidth) - newTF.width;
          else
                 newTF.left = tfLeft;
                          newTF.selected = false;
      function fieldToArray(myField) {
                          retChars = new Array("\x03","\f","\r","\n");
                          var tmpTxt = myField.contents.toString();
                          for (all in retChars )
                  tmpArr = tmpTxt.split(retChars[all]);
                          return tmpTxt.split(ret_re);
