3 Replies Latest reply on Dec 21, 2007 4:23 AM by MKjellberg
    Tree not updating correctly, except when run from Adobe website
    MKjellberg
      I have a little problem, when running http://www.adobe.com/devnet/flex/quickstart/working_with_tree/ (The first example), everything works perfectly. But if i copy that source code, and compile it myself and run it from Flex builder 2 (I have 2.0.1) the tree behaves really strange, when i add an item you see two copies of the "Operations" node, but you can only mouseover one, and as soon as you open or close anything it looks perfectly fine.
      Anyone know whats causing this issue? It shows up in all my applications where i try to add/remove nodes from Tree's in runtime.
      Regards.
