1 Reply Latest reply on Jul 31, 2013 1:20 PM by Brian Havlin
    Creating form in FormsCentral for first time
    KlaraHickmanova
      Good morning,
      I am creating online form in FormsCentral for the first time.
      As I go along, I came accross:
      1. Can I add/move a text field next to the text, instead below?
      sample:
      2. Could the space between lines be increased?
      (meaning "line spacing" -- pressing enter - lines are too far from each other)
      3. I found answer regarding creating "bullets" -
      the recommendation "keyboard num lock ON, hold Alt down and type  7 or 9 - somehow does not work for me.
      Do you have any other idea, except of using '*" and ">" instead of bullets?
      Thanks so much for your help,
      Klara
      klara@arts4mc.org
        • 1. Re: Creating form in FormsCentral for first time
          Brian Havlin Adobe Employee
          Hi Klara,
          1. To change the position of the label relative to the input field, use the "Labels Position" drop-down toward the end of the toolbar. Note that this is currently a form-wide option.
          2. No, it's not possible to increase the spacing between lines.
          3. Try holding down Alt then type 0149. If that doesn't work you could try copy/pasting this character  •  into your form.
          Regards,
          Brian
