2 Replies Latest reply on Oct 9, 2007 12:25 PM by mayank_io
    Error running FB linux
    mayank_io
      First and foremost, thanks a ton for finally porting fb to linux !
      I tried running FB on eclipse 3.2, 3.3, 3.3.1. When I try to open an mxml or as file I get the following error :
      <error>
      Error opening the editor. ( Time of error: October 4, 2007 7:27:32 PM GMT +5:30)
      Reason:
      Assertion Failed:
      </error>
      any clues??
      <stacktrace>
      org.eclipse.jface.util.Assert$AssertionFailedException: Assertion failed:
      at org.eclipse.jface.util.Assert.isTrue(Assert.java:185)
      at org.eclipse.jface.util.Assert.isTrue(Assert.java:170)
      at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.setActivePage(FlexMu ltiPageEditorPart.java:569)
      at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.setActivePage(CodeAndDesi gnEditor.java:625)
      at com.adobe.flexbuilder.editors.mxml.MXMLEditor.setActivePage(MXMLEditor.java:483)
      at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.createPartControl(Fl exMultiPageEditorPart.java:235)
      at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.createPartControl(CodeAnd DesignEditor.java:140)
      at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:661)
      at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:426)
      at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:592)
      at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:263)
      at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1405)
      at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:939)
      at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
      at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
      at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
      at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3296)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2974)
      at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:801)
      at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1342)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
      at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:106)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:585)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
      </stacktrace>
