7 Replies Latest reply on Aug 6, 2013 3:10 AM by try67
    javascript for adding image signature with date in action wizard
      I'm having trouble with adding my scanned signature into 100 PDFs in a batch.
      I found the following javascript code (A) online but it's for adding "invisible signatures".
      As discussed in the above link, I modified (A) to (B) by taking out the login part
      but I don't know if putting my scanned PNG signature as appearance is correct.
      After running the code, I don't see any signature on my PDF.
      I don't know how to add the date and time either.
      Anyone please help?
      Sign all documents
      Batch sequence name: Signature SignAll.sequ.
      Task: Create an invisible signature on each of the selected files.
      Example2.12 Sign all documents
      /* Signature Sign All */
      // Choose handler
      var ppklite = security.getHandler("Adobe.PPKLite");
      // Login -- change as appropriate
      ppklite.login("dps017", "/C/Profiles/DPSmith.pfx");
      // Add a signature field with zero dimensions (invisible)
      var f = this.addField("Signature", "signature", 0, [0,0,0,0]);
      // Sign it and log out. Change as appropriate
      { password: "dps017",
      reason: "I am approving this document",
      contactInfo: "dpsmith@mycompany.com",
      appearance: "DPSmith"});
      addField("Signature", "signature", 0, [200,200,200,200]).signatureSign({appearance: scanned_png});
