16 Replies Latest reply on Aug 1, 2013 7:36 AM by Peter Kahrel
    [CC/JS] Check for Images Containing White Borders
    tobias.wantzen Level 1
      I’m writing a script, that places images (CMYK-JPGs) in frames. So far so good, but when an image has a white background at its top, right, bottom OR left border, then the image frame should get a border in InDesign (30% black).
      Is there an easy way to check this?
      I’d be very glad to get some ideas, starting points, code snippets whatever ...
      Cheers
      Tobias
        • 1. Re: [CC/JS] Check for Images Containing White Borders
          Peter Kahrel Adobe Community Professional & MVP
          Tobias,
          InDesign can't look at pixels. You'd have to use PhotoShop to check the images and if any have a white background, add something to their name (e.g. xyz.jpg > xyz_bg.jpg). Then in InDesign you can recognise the images that need a border by _bg. in their name.
          Peter
          • 2. Re: [CC/JS] Check for Images Containing White Borders
            Jump_Over Level 5
            Agree with Peter, but...
            You could switch image clippingPath type to get a path restricted to frame and use it to create a shape with geometricBounds to be compared with your image gBounds.
            Just an idea...
            to start it:
            mImage  = app.selection[0].graphics[0];
            with (mImage.clippingPath) {
              currClip = clippingType;
                      clippingType = ClippingPathType.DETECT_EDGES;
                      useHighResolutionImage = false;
                      restrictToFrame = true;
                      threshold = 1;
                      mPath = paths[0];     // hm... here can be more paths...
            mShape = app.activeDocument.graphicLines.add({strokeWidth:0.1});
            mShape.paths[0].entirePath = mPath.entirePath;
            mImage.clippingPath.clippingType = currClip;
            assumes: frame (image.parent) is selected
            result: mShape is an object with geoBounds and set of points. How to compare it - that's mathematic effort and your tolerance assumings...
            mShape is to remove() at the end
            Jarek
            • 3. Re: [CC/JS] Check for Images Containing White Borders
              Hi Jarek,
              Nice one. But I assumed that that white background is simply a bunch of white-coloured pixels. Would a clipping path detect those?
              Peter
              • 4. Re: [CC/JS] Check for Images Containing White Borders
                Jump_Over Level 5
                threshold property limits this detection. If == 0 detect edges of white pixels but less number produces more "independent" paths.
                Jarek
                • 5. Re: [CC/JS] Check for Images Containing White Borders
                  @Peter:
                  Thanks for your answer. That’s what I expected.
                  @Jarek:
                  Very nice idea! I’ll give it a try. And to your comment »// hm... here can be more paths...«: When there are more than one path, I definitely have white borders. So the first, simple check would be something like:
                  if ( paths.length !=1 ) // white borders found
                  Regards
                  Tobias
                  • 6. Re: [CC/JS] Check for Images Containing White Borders
                    Maybe something like this:
                    #target InDesign
                              useHighResolutionImage = true;
                              threshold = 3;
                              tolerance = 0;
                              mPath = paths;
                    if (mPath.length != 1) {
                        alert( mPath.length );
                    } else {
                        alert( mPath[0].pathPoints.count() );
                    I’ll test a bit ...
                    Regards
                    Tobias
                    • 7. Re: [CC/JS] Check for Images Containing White Borders
                      Jump_Over Level 5
                      Not true, I am afraid. This could find a paths inside your image, far away from borders as well. It depends on threshold and tolerance and... your image pixels of course.
                      Jarek
                      • 8. Re: [CC/JS] Check for Images Containing White Borders
                        But a path inside my image will only be found, when I set
                        includeInsideEdges = true
                        So I have to add »includeInsideEdges = false« and that’d be it.
                        Or am I missing something?
                        Tobias
                        • 9. Re: [CC/JS] Check for Images Containing White Borders
                          Jump_Over Level 5
                          Hi Thobias,
                          includeInsideEdges = false could decrease a number of paths found but it still can be 10th of them.
                          More I test this idea more I am scared to results
                          • 10. Re: [CC/JS] Check for Images Containing White Borders
                            Jarek,
                            Hoping not to annoy you, but I don’t understand your remark. If I use the clipping path in InDesign (»in the UI«), and do not check »Include Inside Edges« or »Invert Path«, InDesign only tries to find a clipping path from outside to inside (from the object borders as far as it goes) ignoring any white areas _inside_ the image. So I get one path with x points on it (but 1 path). Why should the behaviour of scripting be different to that? Or – the other way around – can you give me an example which illustrates your thoughts?
                            Tobias
                            • 11. Re: [CC/JS] Check for Images Containing White Borders
                              Jarek, this is a fantastic idea! It even works on vector illustrations Tobias, this is what Jarek means:
                              It is a single 'pathitem' but with lots of compound sub-paths.
                              By the way: I found that setting threshold and tolerance to 0 is No Good. It then fails with the simple plain white background above, and all I get is the original rectangle. But if you find the paths are a bit too tight, you can always set the inset value to a small value.
                              There is a caveat: if you cropped your image, the cropped-off part with "invisible" parts will also be considered, and be included in the final path.
                              Other than that: great suggestion! I'm going to take a look at how efficient this is. No more manually cropping images to the nearest pixel!
                              • 12. Re: [CC/JS] Check for Images Containing White Borders
                                Jongware,
                                thanks for your reply. When I recreate your example image, for »mPath = paths.length« I get »6«. I’m no native english speaker, maybe I don’t get the point by misunderstanding something.
                                Your caveat is right: with cropped image the »invisible« part is also considered. (I thought this would not be the case when choosing ».restrictToFrame = true;« ...)
                                But the code I tried - based on Jarek’s idea - solves my problem! Great work - thanks!
                                When someone gets some new insights on this subject, I’d be glad to know!
                                Tobias
                                • 13. Re: [CC/JS] Check for Images Containing White Borders
                                  Tobias, you mentioned you got only a single path for your test image. My example shows it is possible to get more than one.
                                  As to my caveat: you can simply set 'restrictToFrame' to true to solve this. Here is an experimental bit of code; it uses convertToFrame so you can see what happens, but in a final script this won't be necessary.
                                  if (app.selection.length == 1)
                                  img = app.selection[0];
                                  if (img.hasOwnProperty("images") && img.images.length == 1)
                                    img.images[0].clippingPath.properties = {clippingType: ClippingPathType.DETECT_EDGES, restrictToFrame:true, includeInsideEdges:false, threshold:3,tolerance:2, useHighResolutionImage:true};
                                  // paths = img.images[0].clippingPath.paths;
                                    paths = img.images[0].clippingPath.convertToFrame();
                                    paths.strokeWeight = 2;
                                    paths.strokeColor = app.activeDocument.swatches.item("Black");
                                  • 14. Re: [CC/JS] Check for Images Containing White Borders
                                    Jump_Over Level 5
                                    Uff,
                                    three heads are better than one
                                    Jarek
                                    • 15. Re: [CC/JS] Check for Images Containing White Borders
                                      Thanks Jongware, now I understand!
                                      And thanks again Jarek for the genious point in the right direction!
                                      Tobias
                                      • 16. Re: [CC/JS] Check for Images Containing White Borders
                                        Great stuff, Jarek. Thanks.
                                        Peter
