5 Replies Latest reply on Aug 2, 2013 3:10 AM by JohnDevlon
    [5.5][AS][10.8] Error getting font info
    JohnDevlon Level 1
      Hi
      I have a very weird problem using AppleScript and Indesign.
      I'm trying to check if a document has missing fonts.
      When running the script (from the finder), an error occures on some fonts when trying to check the font status.
      The script is able to check the font status on multiple fonts, but not all of them. The error trown: "Unable to retreive the font's UID from it's name".
      When debugging my script, it seems that the script is not able to get any property info of some fonts.
      My Applescript...
      tell application "Adobe InDesign CS5.5"
                tell active document
                          repeat with i from 1 to the number of fonts
                                         set myFont to item i of fonts
             display dialog status of myFont as string
                          end repeat
                end tell
      end tell
      When doing the same thing using a javascript and running it from within Indesign, all works well.
      var Doc = app.activeDocument;
      for (var z =0; z < app.activeDocument.fonts.length ; z++) {
          var test = app.activeDocument.fonts[z];
          alert(test.status);
      alert("done");
      Using the Javascript, I can loop over every font and get all of there properties. All works well.
      Why am i not able to check all font properties on all fonts using Applescript?
      Does anyone have a solution?
      Thanx
        • 1. Re: [5.5][AS][10.8] Error getting font info
          Mac_rk
          try this .....
          var myFonts= myDoc.fonts;
          var myMissing = new Array();
          var myCheckings  = MissingFonts()
          var count=0;
          function MissingFonts()
          for(var i=0; i<myFonts.length; i++)
          if (myFonts[i].status!= FontStatus.INSTALLED)
             myMissing.push(myFonts[i].name+"\n");
             count+=1;
          return myMissing;
          alert (myMissing.length)
          alert (myMissing)
          • 2. Re: [5.5][AS][10.8] Error getting font info
            JohnDevlon Level 1
            Thanks for your feedback. But like I mentioned: the problem occures only in Applescript.... In Javascript everything works fine...
            • 3. Re: [5.5][AS][10.8] Error getting font info
              JohnDevlon Level 1
              I found a temporary "fix"...
              set js to "function Check4MissingFonts() { var bolresult = false;for (var z =0; z < app.activeDocument.fonts.length ; z++) {if (app.activeDocument.fonts[z].status !=  \"INSTALLED\"){bolresult = true;break;};} return bolresult ; }; Check4MissingFonts();"
                do script js language javascript
                display dialog the result
              end tell
              However, I still would like to know how it could be fixed in native Applescript...
              • 4. Re: [5.5][AS][10.8] Error getting font info
                JohnDevlon Level 1
                Apparently I spoke too soon.
                In some occassions. The error still occures...
                • 5. Re: [5.5][AS][10.8] Error getting font info
                  JohnDevlon Level 1
                  This seems to be more stable...
                            repeat with eachFont in fonts
                                      try
                                           if (status of eachFont is not installed and status of eachFont is not not available) then
                                                     display dialog "Missing font!"
                                                     exit repeat
                                           end
                                       on error errMsg
                                       end try
                              end repeat
                         end tell
                  end tell
