1 Reply Latest reply on Aug 1, 2013 9:58 AM by pauland
    Restful and .AS files
    Arundil
      Hi Everyone
      I'm triying to conect a Restful servise to and HTTP servide that I have already created on the app, I already make it work when I specify a field but I want to know how can I make that field a variable
      I already try puting it on {} but it didnt work, please see the code bellow
      package services
                import mx.collections.ArrayCollection;
                import mx.rpc.events.ResultEvent;
                import mx.rpc.http.mxml.HTTPService;
                import spark.collections.Sort;
                import spark.collections.SortField;
                import valueObjects.Loans;
                public class LoansService extends HTTPService
                          [Bindable]
                          public var loanse:ArrayCollection;
                          private var selectedfilter:Number = 0;
                          private var selectedfilter2:String = null;
                          private var Y:Number = 0;
                          private var rolle:String = null;
                          public function LoansService(rootURL:String=null, destination:String=null)
                                    super(rootURL, destination);
                                    this.url="http://16.116.35.71:8080/ezdemo/rest/loan/all/{User}"; <- how can I make User to be taken as a variable
                                    this.resultFormat="e4x";
                                    addEventListener(ResultEvent.RESULT, handleLoansResult)
                          protected function handleLoansResult(event:ResultEvent):void {
                                    var loansArray:Array = new Array();
                                    var resultData:XMLList = event.result..loans;
                                    for each (var l:XML in resultData) {
                                              var loans:Loans = Loans.buildLoan( l );
                                              loansArray.push( loans );
                                    loanse = new ArrayCollection( loansArray );
                                    loanse.filterFunction = filterForCategory;
                                    loanse.refresh();
                          private function filterForCategory( item:Loans ):Boolean{
                                    var id:int = selectId(item.status)
                                    switch(rolle)
                                              case "accountManager":
                                                        if (selectedfilter != 0){
        if (id == selectedfilter){
        if (item.accountManager == selectedfilter2){
        return true;
        else return false;
        else return false;
                                                        else{
        return true
        else {return false}
                                                        break;
                                              case "isr":
        if (item.isr == selectedfilter2){
        return true;
        else return false;
        else return false;
                                                        else{
        return true
        else {return false}
                                                        break;
                                              case "isa":
        if (item.isa == selectedfilter2){
        return true;
        else return false;
        else return false;
                                                        else{
        return true
        else {return false}
                                                        break;
                                              default:
                                                        return false;
                                                        break;
                          public function receive(u:String, r:String):void{
                                    selectedfilter2 = u;
                                    rolle = r;
                          public function filterCollection(u:String, x:Number, r:String):void{
                                    selectedfilter = x;
                                    rolle = r;
                                    loanse.refresh();
                          public function sortTable(inc:Number):void
                                    var sort:Sort = new Sort();
                                    var sorted:String;
                                    var numb:Boolean;
                                    switch(inc)
                                              case 0:
                                                        sorted = "companyName";
                                                        numb = false;
                                                        break;
                                              case 1:
                                                        sorted = "loan";
                                                        numb = true;
                                                        break;
                                              case 2:
                                                        sorted = "status";
                                                        numb = false;
                                                        break;
                                    var sortfield:SortField = new SortField(sorted,false,numb);
                                    sort.fields = [sortfield];
                                    loanse.sort = sort;
                                    loanse.refresh();
                          private function selectId(o:String):int
                                    var i:int;
                                    switch (o)
                                              case "Product":
                                                        i = 1;
                                                        break;
                                              case "Approvals":
                                                        i = 1;
                                                        break;
                                              case "Allocation":
                                                        i = 1;
                                                        break;
                                              case "Drop Ship":
                                                        i = 1;
                                                        break;
                                              case "Shipping":
                                                        i = 1;
                                                        break;
                                              case "Open Placement":
                                                        i = 2;
                                                        break;
                                              case "Force Clousure Risk":
                                                        i = 2;
                                                        break;
                                    return i;
