1 Reply Latest reply on Jun 13, 2006 10:15 AM by Newsgroup_User
    Random and Arrays problem
    sbryner Level 1
      Hello,
      I'm trying to select a random number between 1 and 3. Add text in front to create my array name...
      (example: myArray3).
      The code below is what I've come up with. Am I way out in left field or am I somewhat close?
      not sure if var Arrays should be in a function or not?
      Please review code and help me dicipher what I'm doing wrong. I'm just trying to practice new things and understand all this AS stuff.
      I believe I'm not getting the random number into my function. So randRange = null. would I put randRange()
      and in my function (myStoryArray[randRange()]);
      Thanks for any help,
      Sky
        • 1. Re: Random and Arrays problem
          Level 7
          var storyName = myStoryArray[randRange(1,3)];
          Lon Hosford
          www.lonhosford.com
          Flash, Actionscript and Flash Media Server examples:
          http://flashexamples.hosfordusa.com
          May many happy bits flow your way!
          "sbryner" <webforumsuser@macromedia.com> wrote in message
          news:e6mqoa$otr$1@forums.macromedia.com...
          > Hello,
          > I
          > somewhat close?
          > trying
          > Sky
          > //....................................... Select a random number between 1
          > 3...................................................\\
          > function randRange(min:Number, max:Number):Number {
          > var randomNum:Number = Math.floor(Math.random()*(max-min+1))+min;
          > return randomNum;
          > for (var i = 0; i++; ) {
          > var n:Number = randRange(1, 3);
          > //........................................................................Functi
          > on....................................................\\
          > myBtn_mc.onRelease = function() {
          > randRange; // calls the random function and retrieves a random
          > number 1
          > - 3
          > var myStoryArray:Array = new Array(); //creates new array called
          > myStoryArray
          > myStoryArray[1] = "My, oh my "+(vFirst)+" "+(vLast)+" array # 1 is
          > here!";
          > myStoryArray[2] = "Well, "+(vFirst)+" "+(vLast)+" Array # 2 works.";
          > myStoryArray[3] = "Hello "+(vFirst)+" "+(vLast)+" This is array # 3.";
          > //lists 3 myStoryArrays
          > var vFirst = fName_txt.text; // sets vFirst = to text in a field
          > var vLast = lName_txt.text; // sets vLast = to text in a field
          > fName_txt._visible = false; // turns visible off of input field
          > lName_txt._visible = false; // turns visible off of input field
          > var storyName = (myStoryArray[randRange]); // sets storyName to
          > myStoryArray[]
          > // (exmpl: myStoryArray3)
          > storyBox_txt.text = storyName; // puts text of array variable
          > name(myStoryArray
          > // into the text of storyBox_txt.
