2 Replies Latest reply on Jun 13, 2006 4:54 AM by Newsgroup_User
    passing function name into another function?
    Level 7
      Hi
      I have a movieclip prototype thats scales and moves any movieclips depending
      on the parameters passed in. I want to be able to pass in a function name
      that is executed when the main function has finished. The problem is the
      line of code that calls the main function executes the function name that I
      m trying to pass in as a parameter. Is there something I m missing?
      see my code below:
      "mcMainAnimation.moveFadeTransform(0, mcMainAnimation._y, -100,
      mcMainAnimation._xscale, -30, 50,moveToX());"
      MovieClip.prototype.moveFadeTransform = function(t, oldY, diffY, oldScale,
      newScale, tTime, funcToCall) {
      this.onEnterFrame = function() {
      t++;
      if (t<=tTime) {
      this._y = easeIn(t, oldY, diffY, tTime);
      this._xscale = easeIn(t, oldScale, newScale, tTime);
      this._yscale = easeIn(t, oldScale, newScale, tTime);
      } else {
      t = 0;
      funcToCall;
      this.onEnterFrame = null;
      moveToX = function () {
      trace("called");
      Thank in advance
      Shaun
        • 1. Re: passing function name into another function?
          Level 7
          Hi!
          Try to modify code to:
          mcMainAnimation._xscale, -30, 50,moveToX);"
          ... so don't use () at end of function. That should do the trick.
          Also, you need to add the () to funcToCall, so that instead of:
          t = 0;
          funcToCall;
          you should have
          t = 0;
          funcToCall();
          /Jensen/
          "forums.macromedia.com" <shaun@thetouchagency.co.uk> wrote in message
          news:e6m428$qa0$1@forums.macromedia.com...
          > Hi
          > depending on the parameters passed in. I want to be able to pass in a
          > function name that is executed when the main function has finished. The
          > problem is the line of code that calls the main function executes the
          > function name that I m trying to pass in as a parameter. Is there
          > see my code below:
          > t++;
          > if (t<=tTime) {
          > } else {
          > t = 0;
          > funcToCall;
          > trace("called");
          > Thank in advance
          > Shaun
          • 2. Re: passing function name into another function?
            Level 7
            Try this:
            MainAnimation._xscale, -30, 50,"moveToX");"
            t++;
            if (t<=tTime) {
            } else {
            t = 0;
            this[funcToCall]();
            trace("called");
            Remove '_spamkiller_' to mail
