1 Reply Latest reply on Aug 2, 2013 2:32 AM by GZRenaud
    Compiling Issue in Flash Pro CS6
    GZRenaud
      When I try to test my project (CTRL + Enter), it displays a blank window if publication target is superior or equal to 10.3, in Flash Pro CS6, either AS2 or AS3. Even if it's a new empty project with just a background color set and a trace("ok"); on the first frame, it does strictly nothing. White and no message in the debug console.
      If I change the target to 9, it works, although the scene color is still not displayed.
      In both cases, when I open the generated swf file directly from my explorer (Windows 7), it works, although the scene color is not displayed.
      Worked perfectly until now, can't remember of a recent update but maybe the last one did that.
      Does anyone know how to fix that ?
      Thank you !
        • 1. Re: Compiling Issue in Flash Pro CS6
          GZRenaud Level 1
          Hey,
          I've solved my problem installing the Flash Pro CC trial version.
          I wanted to test if it worked under CC, but it seems to have solved the problem in Flash CS6 too. Everything is back to normal.
          I guess we can say this is a solved issue, even if I don't know why. Maybe reinstalling Flash CS6 would have done the trick too. Can't tell.
