4 Replies Latest reply on Jul 27, 2014 8:50 AM by Xoco
    Typekit Trial
    Xoco Level 3
      I try to get a font from Typekit Trial: http://typekit.com/fonts?collection=trial&language=ca&sort=name like 'Acta Display', but this font not appears in Edge Web Fonts selection screen, why? how I use this group of trials fonts?
        • 1. Re: Typekit Trial
          elainecc Adobe Employee
          Hi, Josep-
          The TypeKit workflow is different than the Edge Web Fonts workflow.  In order to use TypeKit, you should click on the Custom Tab in the Fonts section and then follow the directions here:
          http://tv.adobe.com/watch/learn-edge-animate/using-typekit/
          -Elaine
          • 2. Re: Typekit Trial
            Xoco Level 3
            More info: TYPEKIT | Embed Code
            First, is necessary add new kit (use fonts) and get kitId. With a Trial Plan, you may only create 1 kit.
            Second, this code (loads the Typekit fonts asynchronously on your site):
              (function(d) {
                var config = {
                  kitId: 'xxxxxxx',
                  scriptTimeout: 3000
                h=d.documentElement,t=setTimeout(function(){h.className=h.className.replace(
            /\bwf-loading\b/g,"")+" wf-inactive";},config.scriptTimeout),tk=d.createElement(
            "script"),f=false,s=d.getElementsByTagName("script")[0],a;h.className+=" wf-loading";
            tk.src='//use.typekit.net/'+config.kitId+'.js';tk.async=true;tk.onload=tk.onreadyst
            atechange=function(){a=this.readyState;if(f||a&&a!="complete"&&a!="loaded")return;
            f=true;clearTimeout(t);try{Typekit.load(config)}catch(e){}};s.parentNode.insertBefore(tk,s )
              })(document);
            </script>
            • 3. Re: Typekit Trial
              Xoco Level 3
              Is possible to load asynchronously Edge Web Fonts (not Typekit) for to load faster the website with Edge 3.0?
              • 4. Re: Typekit Trial
                Xoco Level 3
                Or any possibilty to load asynchronously Edge Web Fonts (not Typekit) for to load faster the website with Edge CC 2014?
