1 Reply Latest reply on Aug 5, 2013 9:29 AM by Captiv8r
    I need help with the conditional build tag option RoboHelp 10
    newcheese
      I need help with the conditional build tag option. I want to apply CBT to content in a topic. I looked at the Help topics and believed that I applied the feature correctly. Howver, it is not working as desired. In the 2nd sentence below I want the text highlighted in blue to only appear for the printed output and the text printed in purple to only appear for the .htm /online output. Please help.
      There are common tasks used to manage the folders in the Navigator and the folders
      in the BBS Folders Viewer Grid. For more information on these common tasks see Help
      and Support in Success Enterprise. click the links below.
        • 1. Re: I need help with the conditional build tag option RoboHelp 10
          Hi there
          Using tagging is a two part process.
          Part One
          You create and apply the tags to the information you wish to control.
          Part Two
          You create a Build Expression that is used when you generate your output. The Build Expression typically reads something like: NOT Tag1 (or whatever your tag name is)
          Then when you generate and use the Build Expression, the information tagged is not included in the build.
          Cheers... Rick
