3 Replies Latest reply: Aug 5, 2013 10:16 AM by A.T. Romano RSS
    rendu  vidéo  impossible !....
    danyfarro
      bojour,  j'utilise  Adobe Premiere  Elements  10  ,   auparavant   je  n'avais   aucun   probléme , mais pour ma dernier  vidéo , il  m'est  impossible  de faire  un rendu  de ma vidéo , la progression  au niveau  du compteur ce fait  normalement  , mais la barre  rouge ne bouge  pas .  Que faire ?.... ci-joint  une capture  d'écran .Sans titre10.jpg
        • 1. Re: rendu  vidéo  impossible !....
          John T Smith CommunityMVP
          Google Translate
          Helo, I use Adobe Premiere Elements 10, before I had no problem, but for my last video, it is impossible for me to render my video, progress at the counter that normally, but the bar red does not move. What to do? .... Attached is a capture
          These questions below may be for a different product... but the information you need to supply is the same, for the products you use
          More information needed for someone to help... please click below and provide the requested information
          -Information FAQ http://forums.adobe.com/message/4200840
          Windows or Mac... and what are you editing?
          Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
          What is a CODEC... a Primer http://forums.adobe.com/thread/546811
          What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
          Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
          http://forums.adobe.com/thread/592070?tstart=30
          For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
          For Mac http://mediainspector.massanti.com/
          • 2. Re: rendu  vidéo  impossible !....
            Bill Hunt CommunityMVP
            One thing that I see is that your WAB (Work Area Bar) is not over all Clips in the Timeline. That will limit the area that is Rendered.
            Google Translate:
            Une chose que je vois, c'est que votre WAB (Work Area Bar) n'est pas sur tous les plans dans la timeline. Cela va limiter la superficie qui est rendu.
            This article, in English, gives more info on the WAB: http://forums.adobe.com/message/5170142#5170142
            • 3. Re: rendu  vidéo  impossible !....
              A.T. Romano Community Member
              danyfarro
              Il est évident à partir de votre écran que vous êtes en train de faire volontairement rendu sélectif pour le contenu Timeline utilisant les onglets gris de la zone de travail Bar pour définir la zone pour le rendu. À ce stade, je n'ai aucune raison de croire qu'ils n'ont rien à voir avec votre question.
              La capture d'écran montre clairement que vous ne pouvez pas aller plus loin que le numéro de châssis 2937 pour atteindre la fin du segment au numéro de châssis 9712.
              Donc, j'ai ces questions pour éclaircir les choses.
              Si vous déplacez la zone de travail Tabs Bar à couvrir l'ensemble des 17 minutes de contenu, le programme va rendre l'ensemble 17 minutes ou cela s'arrêtera au cadre 2937?
              Si vous déplacez la zone de travail Tabs Bar à couvrir une partie du contenu entre 9712 châssis et la dernière image du scénario de 17 minutes, le programme va rendre ce nouveau segment que vous avez sélectionné avec les onglets de la barre d'espace de travail?
              Quel genre d'. Avi Travaillez-vous avec? AVI n'est que le prolongement, le format d'enveloppe du fichier. Quelle est la compression vidéo et audio?
              S'il vous plaît allez dans le dossier Adobe, en particulier pour la Premiere Elements Preview dossier des fichiers Adobe et voir si vous avez un énorme tas d'fichiers. En outre, la caisse du menu Edit / Preferences / Disques de travail pour s'assurer que vous les avez dirigés vers une zone avec suffisamment d'espace sur le disque dur à accepter.
              S'il vous plaît ne pas hésiter à demander si vous avez besoin d'éclaircissements sur tout ce que j'ai écrit.
              Merci à vous.
              ATR
              English Version Of My Post
              It is obvious from your screenshot that you are purposely doing selective rendering for the Timeline content using the gray tabs of the Work Area Bar to define the area for rendering. At this point, I have no reason to believe that they have anything to do with your issue.
              The screen shot clearly shows that you cannot get any further than frame number 2937 to reach the end of your segment at frame number 9712.
              So, I have these questions to clear up matters.
              If you move the Work Area Bar Tabs to span the whole 17 minutes of the content, will the program render the whole 17 minutes or will it stop at frame 2937?
              If you move the Work Area Bar Tabs to span any portion of the content between 9712 frame and the last frame of the 17 minute Timeline, will the program render this new segment that you have selected with the Work Area Bar tabs?
              What kind of .avi are you working with? AVI is just the file extension, wrapper format. What is the video and audio compression?
              Please go to the Adobe Folder, specifically to the Adobe Premiere Elements Preview Files Folder and see if you have a huge pile up of files there. Also, checkout the Edit Menu/Preferences/Scratch Disks to assure that you have them directed to an area with enough hard drive space to accept them.
              Please do not hesitate to ask if you need clarification on anything that I have written.
              Thanks you.
              ATR
