3 Replies Latest reply on Aug 6, 2013 11:05 AM by kglad
    Understanding Mouse events
    Charine -FB buggoop
      I want to build a word game where a player clicks on a letter tile to copy a word on screen. I want to know how this mouse event will work.
      I have an array of letter tiles:
                private var letterTiles:Array = [a,b,c,.....etc]
      Each letter has it's own class file like this:
      package
        import flash.display.MovieClip;
        import flash.text.*;
          public class A extends MovieClip
              public var tileLetter:String = "a";
              public function A()
                // constructor code
      they are shuffled and placed on screen. The next function is to see which letter was clicked on. I have
      public function initLetterWasClickedOn():void
                          for(var i:int=0;i<letterTiles.length;i++)
                              letterTiles[i].addEventListener(MouseEvent.MOUSE_DOWN, onClickLetter);
                          function onClickLetter(e:MouseEvent):void
                                  trace(e.currentTarget.name);
      In my output panel, when I click on a letter I get: element 26, element 1 etc.
      Thing is, I never named anything element # whatever. These elemant numbers do not correspond to the position of the letter in the array either. I see that letter tile 's' for example is alway element 26. Where do these names come from?
      More importantly - can I just go ahead and write code to compare letters:
      if (currentTarget.name == activeLetterInWord)
      {do these;}
      else{do these;}
      Charine
        • 1. Re: Understanding Mouse events
          assign names:
          letterTiles[i].name=i.toString();
          //letterTiles[Number(e.currentTarget.name)] is the clicked array element
          or, if those array elements are movieclips, you can just assign their index to be a movieclip property:
          letterTiles[i].ivar=i;
                                      trace(MovieClip(e.currentTarget).ivar);
          • 2. Re: Understanding Mouse events
            Charine -FB buggoop Level 1
            Hi kglad,
            They are indeed movieclips. I did as you suggested. See code below, but altough my swf file runs, I get the following error code on every click:
            ReferenceError: Error #1056: Cannot create property ivar on A.
                at LetterArray/initLetterWasClickedOn()
                at LetterArray/gameLoop()
                at BugGoopFSGame/gameLoop()
                at flash.utils::Timer/_timerDispatch()
                at flash.utils::Timer/tick()
            Here is the code with changes as you suggested:
                                        trace(e.currentTarget.ivar);
            • 3. Re: Understanding Mouse events
              if A extends MovieClip, use:
                                      MovieClip(letterTiles[i]).ivar=i;
