1 Reply Latest reply on Aug 5, 2013 3:47 PM by Peter Spier
    Creating Spaces in Table of Contents
    Andymc7 Level 1
      Hi everyone,
      I have a nagging problem that I'm sure has a simple solution. Here is a very simple TOC I've set up with ID's automated feature. However, I'm trying to figure out how to add some spacing before and after the underlined style, instead of having it run right up to the section name and page number as you see here...
      Here's a shot of my TOC setup. Like I said, very simple at this point...
      I've tried many different types of special characters in the "Between Entry and Number:" drop down, with now luck. I realize I can manually type a couple spaces after my headings and before my page numbers, but I'd prefer to do it with the TOC feature.
      Any help is greatly appreciated. Thanks in advance!
        • 1. Re: Creating Spaces in Table of Contents
          You can add spaces either side of the tab in the Between Entry and Number field (pick them fom the list when you click the arrow), but you don't want to use a style to add the underline here. Instead, add it as a nested style inthe paragraph style you assign to the listings: None up to 1 Right Indent Tab, the underline style through 1 Right Indent Tab...
