1 Reply Latest reply on Aug 5, 2013 7:19 PM by Mylenium
    3D Snapping And Camera Problem
    MythosGreer
      Hello All,
      I'm currently working on a large After Effects Project involving multiple compositions, and on my latest I've run into a snag whenever I try to turn a 2d image into a 3d layer using the 3d on and off switch in the column next to the given layer.
      Whenever I select the 3D option in the timeline columns for the layer, the whole composition snaps to the side. The image bellow is what occurs after I do this.
      Something similar happens with particle world and the camera. Whenever use particle world, the graph is completely flat, and when I bring in a camera, I can move the camera, yet not view the graph in 3d. Rather I get a 2d side image of the camera and I move it around, unable to check out what it would look like in 3D. Again as demoed in the images bellow.
      Bellow is just the particles
      And next is what happens when I add the camera
      Now I've looked into my other compositions, and the 3d column option works perfectly fine in those, yet it's only this one that has the problem. If anyone has any idea as to what's causing this problem I would appreciate it.
