3 Replies Latest reply on Aug 7, 2013 1:16 AM by BEGINNER_X
    Find dpi & Align center of Image
    BEGINNER_X Level 3
      Hi All,
      I have new request but struggling in the below points:
      1. Find less than 300 dpi image in the active document
      2. Create text frame and fix center of the image vertically and horizotally.
      Hope I completed the script by 90%
      Completed Script:
      var myGraphics = app.activeDocument.allGraphics;
      var targetResolution = 300;
       for (var i = 0; i < myGraphics.length; i++) {
          try
          if (myGraphics[i].effectivePpi[0] < 300) {
              var myPPI = myGraphics[i].effectivePpi[0] + " dpi"             //please ensure this line should be correct
              var myName = myGraphics[i].itemLink.name;
              var myPage = myGraphics[i].parentPage;
              var myCaption = myPage.textFrames.add();
              myCaption.textFramePreferences.verticalJustification = VerticalJustification.TOP_ALIGN;
              myCaption.contents = "FPO\r" + myName + "\r" + "Low Res " + myPPI;
              var bnds = myGraphics[i].parent.visibleBounds;
              myCaption.visibleBounds = [bnds[2] + 3, bnds[1], bnds[2] + 6, bnds[3]];
              myCaption.fit(FitOptions.FRAME_TO_CONTENT);
              try {
                  var myPStyle = app.activeDocument.paragraphStyles.add({name: "Caption_lowres", justification: Justification.CENTER_ALIGN});
              } catch (myError) {
                    myCaption.parentStory.appliedParagraphStyle = app.activeDocument.paragraphStyles.item("Caption_lowres");
              myPage.groups.add([myCaption, myGraphics[i].parent]);
      catch(myError)
      REQUIRED OUTPUT
      But Current Output using above script
      Beginner_X
        • 1. Re: Find dpi & Align center of Image
          Dave Saunders Level 4
          What you need to do is work out the center-point of the graphic:
          var center = {x : (bnds[1] + bnds[3])/2, y : (bnds[0] + bnds[2])/2}
          Then, after making your text frame, populating and fitting it, get its center point by using its bounds, and assign it to a similar variable:
          var capCenter = {x : (capbnds[1] + capbnds[3])/2, y : (capbnds[0] + capbnds[2])/2}
          Armed with this information, you can now do a relative move:
          myCaption.move(undefined, [center.x - capCenter.x, center.y - capCenter.y]);
          And your caption will be centered over the graphic.
          Dave
          • 2. Re: Find dpi & Align center of Image
            BEGINNER_X Level 3
            Hi Mr.Dave,
            Thank you for your response...
            I trying your code but I am not able to get the output.
            Could you help to get the output for me.
                try
                    try {
                    } catch (myError) {
            catch(myError)
            Help me to get output as per attached screenshot
            Beginner
            • 3. Re: Find dpi & Align center of Image
              BEGINNER_X Level 3
              Hi ALL,
              I found the answers in different way...
              Thanks to forum and Mr.Dave
                      myCaption.contents = "FPO\r";
                      app.select([myCaption, myGraphics[i].parent])
                      app.activeDocument.align(app.activeDocument.selection, AlignOptions.TOP_EDGES, AlignDistributeBounds.ITEM_BOUNDS);
                      app.activeDocument.align(app.activeDocument.selection,AlignOptions.VERTICAL_CENTERS, AlignDistributeBounds.ITEM_BOUNDS);
                      var myPageGroup = myPage.groups.add([myCaption, myGraphics[i].parent]);
              Thanks Forum
              Beginner
