1 Reply Latest reply on Aug 7, 2013 12:39 PM by erwinpenCKin
    Different output from essentially Identical IDML for different output types
    erwinpenCKin
      I am testing a website enhancement locally that uses ID CS6, which i have running via the command prompt. The page first displays a .jpg preview of the file you are designing which is working correctly. When the user is finished editing the document they save it to a PDF but that PDF never matches the jpg in that a group of fields are always missing.
      I extracted all the contents of the IDML files being used to generate the two files and combed through them and they are essentially identical. The only difference between them is any reference to the file path of IDML file and the file type I am passing to ID to generate.
      Here is the JPG
      And the PDF
      I can provide exerpts from any file found within the IDML if it will help.
      Any and all help is appreciated!
