4 Replies Latest reply on Aug 7, 2013 12:30 PM by Navarro Parker
    Powerfull Machine - Underwhelming Render Times
    rtylerky
      Hey guys, I have spent thae past few days trying to get my head around multiprocessing in AE CC. I have a pretty beasty computer with lots of power. Its possible that im simply expecting too much but i want to be sure!Windows
      Im running Windows 7 Enterprise 2008
      I have 32 cores in total (with hyper threading)
      64GB Ram
      Quadro 4000
      I started a pretty basic comp just to do some bench marking. Its 8 seconds long and is just of some text being formed out of sand (using Trapcode Form). It takes me around 3 mins to render out 6 seconds of that. Does that seem reasonable?p
      Thats at full resolution 1080p 30fps
      Also, I noticed that Multiprocessing only seems to work for the first 50 frames or so, then it just switches out to rendering 1 frame at a time. Any idea why this might be?
      Cheers!
        • 1. Re: Powerfull Machine - Underwhelming Render Times
          Todd_Kopriva Level 8
          Yes, that is a short render time.
          Sometimes,depending on effects and other items used, each frame may take minutes to render.
          You haven't preserved enough RAM for use by processes other than the background rendering processes. When the foreground RAM cache fills up (or when another application on your system wants RAM), the background processes need to stop rendering and return the RAM for use by these other processes.
          See this page for information about memory and improving performance in After Effects: http://adobe.ly/dC0MdR
          • 2. Re: Powerfull Machine - Underwhelming Render Times
            rtylerky Level 1
            Thanks Todd, This pretty much confirms my own research
            The only thing im still a bit mistified on is the amount of ram i should be reserving. From my somewhat basic understanding of how a computer works i thought i had dedicated plenty! I did 7 different configerations and the bellow image is the one that rendered quickest for me. However it still seemed to stop multiprocessing after the first 50 frames. Am looking at upgrading the RAM to 128Gb
            Any suggestions on this current configuration?
            Cheers!
            • 3. Re: Powerfull Machine - Underwhelming Render Times
              For starters, try using fewer CPUs (reserve more CPUs for other applications). Follow the link that I gave above and read the article that it refers to about not overscheduling your processors.
              Also, the rule of thumb is to start by reserving 1/3-1/4 of your installed RAM for other processes.
              • 4. Re: Powerfull Machine - Underwhelming Render Times
                Navarro Parker Level 3
                This is just my own personal experience, so certainly listen to Todd more than me... but try to reserve 1/2 or more of your available hyperthreaded cores for other apps and see if that helps.
                Keep your available AE CPUs equal to or less than the number of real physical CPU cores you have (in your case 16 or less). Also, AE seems to handle multiprocessing better after a fresh machine reboot. (YMMV)
                Are you rendering to an SSD?  Is your Global Performance Cache on an SSD? Having 30 instances of any app reading and writing to the same HDD is going to be a strain on your I/O bandwidth.
