• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to make text stop wrapping around an image?
Explorer ,
Aug 06, 2013 Aug 06, 2013
Hello:
I am using RoboHelp HTML 10 on Windows 7, generating PDF and webhelp.
My project includes some images with text wrapping to the right of the image. I would like to allow a certain amount of the text to appear next to the image, then force the wrapping to stop at a specific sentence. I want the next paragraph to be aligned with the left margin instead of continuing to wrap around the image.
This is the effect I want:
I want paragraph A to appear next to the image, and paragaph B to be aligned with the left edge of the topic. It is OK for there to be some white space below paragraph A.
Is there a way to make this happen?
Regards,
Juliette Curtis
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Aug 07, 2013 Aug 07, 2013
Rh10 has a new item in the Style Dropdown in the Style Pod. There you can create styles that you apply to images to do just what you have described.
You have to select the image and then apply the style.
@petergrainge
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks for the quick reply Peter.
I was able to create an image style that makes the text wrap to the right of the image. However, I can't work out how to make the text stop wrapping in a specific place. This image shows what is happening:
I want to allow paragraph A to appear to the right of the image and force B to appear below the image, as shown in the first image. The problem is that I don't know how to make B do what I want. Is there a way to do this?
Thanks again for your help.
Regards,
Juliette
Votes
Translate
Translate
Report
Report
Community Expert ,
See if just pressing enter a few times does it. If not, I would have to look at it later.
@petergrainge
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Another approach would involve inserting an invisible table with two columns. Insert the image in the left column and insert the desired paragraph into the right.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
Sep 04, 2013 Sep 04, 2013
Hi Rick:
I'm using your table idea and it is working nicely.
Thanks!
Juliette
Votes
Translate
Translate
Report
Report
New Here ,
Jan 08, 2014 Jan 08, 2014
Hi Rick,
I also have this problem so I followed your table advice. It's actually a brilliant idea and working great on PDF and CHM, but when I printed the PDF, the vertical grid (a white line) on my second column (just have two columns, shaded red, btw) shows. Is there a way to correct this? Thanks!
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
I'll have to defer to my dear friend Peter. He's the print guru. Personally, I have a propensity for not killing trees and believe on-line help should be exactly that.
So perhaps Peter will have a suggestion here.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
I did some experiments on table borders. If I set the table and cell border to 'none', then the white line is not showing on the printed page. But if set it to just have the outside border, then the vertical white line in the middle of my two column table shows on the printed page. I think I can live with totally no border for now because my table is shaded, so I'll be fine.
And Rick, I am pro-environment and always wanted to save trees as well! It's just that we have to deliver this document in multiple formats. ~sighs~
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 09, 2014 Jan 09, 2014
LATEST
Outside border in the Table Editor refers to the outside border of the table, not the cells.
I suspect you need to set the first column right border to be the same colour as the shading.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
