how to color the tabs of <cflayout>? Because i am getting an error in java script "
Uncaught TypeError: Object [object Object] has no method 'getTab'"?? please help me out...
One of the way would be by calling your defined css style as in below code, whereas you can define one or more attributes in that css style:-
<cflayout
type="border|hbox|tab|vbox" align="center|justify|left|right" name="string
" padding="integer
style="your_defined_css_style"
tabHeight="measurement
" tabPosition="top|bottom">
cflayoutarea tags
</cflayout>
In this way, you would be able to implement that.
Whereas for error, it looks that getTab is not defined there.
Regards,
Kaif Akbar
Message was edited by: Kaif Akbar
thanks for reply akbar...
See my basic problem is i am getting an error of undefined method getTab();in javascript
in following code:
var colorTab = function(tab, tabName, color)
// get the underlying EXT object for the tab layout
var tabs = ColdFusion.Layout.getTabLayout(tab);
// get the tab you want to color
var tab = tabs.getTab(tabName);
// set the color of this tab via the DOM
tab.el.dom.firstChild.firstChild.firstChild.style.color = color;
there is no method getTab() in coldfusion9.
so please tell me alternative method to getTab() method.
please help me out.
