6 Replies Latest reply: Aug 26, 2013 4:33 AM by Rob Dillon RSS
    Interval between menu rows?
    kisjans Community Member
      Hi guys,
      I have a flash menu, on page in swf. I have the swf and fla file. I added more buttons and now it fits in two rows but the second row is way to far away from the first row. How can I close the gap between the two rows?
      http://imageshack.us/photo/my-images/23/s6fv.jpg/
        • 1. Re: Interval between menu rows?
          Rob Dillon CommunityMVP
          How did you make the menu? How do you get these buttons on the stage?
          • 2. Re: Interval between menu rows?
            It was a premade menu exported to swf, managed with xml database. I can't find any option to set this, only the text position and the flash box size :/
            • 3. Re: Interval between menu rows?
              It sounds like the controls that you are looking for are inside the .swf. Do you have access to the original .fla file that was used to make the menu?
              • 4. Re: Interval between menu rows?
                I can only decomply the swf and export into an fla file, i dont have the original fla sadly.
                • 5. Re: Interval between menu rows?
                  Found some editable sprites:
                  // Action script...
                  // [Action in Frame 1]
                  menu_label = new Array();
                  menu_url = new Array();
                  var flashmo_xml = new XML();
                  flashmo_xml.ignoreWhite = true;
                  flashmo_xml.onLoad = function ()
                      var _loc3 = this.firstChild.childNodes;
                      for (var _loc2 = 0; _loc2 < _loc3.length; ++_loc2)
                          menu_label.push(_loc3[_loc2].attributes.item_label);
                          menu_url.push(_loc3[_loc2].attributes.item_url);
                      } // end of for
                  flashmo_xml.load("menu_items.xml");
                  // Action script...
                  // [Action in Frame 2]
                  this.onEnterFrame = function ()
                      if (flashmo_xml.loaded)
                          play ();
                          delete this.onEnterFrame;
                      } // end if
                  stop ();
                  // Action script...
                  // [Action in Frame 3]
                  stop ();
                  menu_item_group.menu_item._visible = false;
                  var spacing = 5;
                  var total = menu_label.length;
                  var distance_x = menu_item_group.menu_item._width;
                  spacing;
                  var distance_y = menu_item_group.menu_item._height + spacing;
                  var i = 0;
                  var j = 0;
                  var k = -1;
                  while (i < total)
                      menu_item_group.menu_item.duplicateMovieClip("menu_item" + i, i);
                      menu_item_group["menu_item" + i].over = true;
                      menu_item_group["menu_item" + i].item_text.text = menu_label[i];
                      menu_item_group["menu_item" + i].item_url = menu_url[i];
                      if (i % 10 == 0)
                          j = 0;
                          ++k;
                      } // end if
                      menu_item_group["menu_item" + i]._x = j * distance_x;
                      menu_item_group["menu_item" + i]._y = k * distance_y;
                      ++j;
                      menu_item_group["menu_item" + i].onRollOver = function ()
                          this.over = false;
                      menu_item_group["menu_item" + i].onRollOut = menu_item_group["menu_item" + i].onDragOut = function ()
                          this.over = true;
                      menu_item_group["menu_item" + i].onRelease = function ()
                          getURL(this.item_url, "");
                      menu_item_group["menu_item" + i].onEnterFrame = function ()
                          if (this.over == true)
                              this.prevFrame();
                          else
                              this.nextFrame();
                          } // end else if
                      ++i;
                  } // end while
                  • 6. Re: Interval between menu rows?
                    You have two variables that are defined in the frame 3 actionscript: distance_y and k. It looks like you can change the distance between the rows of buttons by changing the value of distance_y.
