3 Replies Latest reply on Aug 7, 2013 2:18 PM by 131772el
    help in foontone
    131772el
      Hello!
      My name is Eliezer, and I do not speak English.
      The discussion is translated with Google Translate ...
      Aqua your generous assistance:
      I wrote this script:
      var myname="החלת הגדרות";
      try{
      app.doScript (myscript,ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, myname);
      function myscript(){
      //שמור למשתנים נתוני סרגל מקוריים
      var my1=app.activeDocument.viewPreferences.properties;
      /*************אפס כל הסרגלים והמידות לפוינטים**********************************************/
      app.activeDocument.viewPreferences.typographicMeasurementUnits = MeasurementUnits.points;
      app.activeDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
      app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
      var my2=app.activeDocument.footnoteOptions.properties;
      app.activeDocument.viewPreferences.properties=my1;
      for (var a=1;a<app.documents.length ;a++){
      var my3=app.documents[a].viewPreferences.properties;
      app.documents[a].viewPreferences.typographicMeasurementUnits = MeasurementUnits.points;
      app.documents[a].viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
      app.documents[a].viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
      app.documents[a].footnoteOptions.properties=my2;
      app.documents[a].viewPreferences.properties=my3;  //החזר להגדות מקור את הסרגלים
      alert ("בוצע");
      }catch(e){myscript()};
      And he works not good.
      Color and settings of the line before footnotes does not change. (Only the tint of his variable).
      What mistake?
      Thank you very much.
        • 1. Re: help in foontone
          TᴀW Adobe Community Professional & MVP
          Hi Eliezer,
          I think the reason is that properties that require accessing
          sub-properties are not stored in your variable my2. Only the first level
          of properties are. So (I suspect) that if you run the following line
          app.activeDocument.footnoteOptions.properties.toSource()
          you'll find that any properties which require a "resolve" command won't
          get applied.
          אריאל
          • 2. Re: help in foontone
            Hi Eliezer,
            of properties are. So (I guess) that if you run the following line
            get applied.
            Ariel
            • 3. Re: help in foontone
              131772el Level 1
              Thank you
              Yes, that appears with the "resolve" does not work ...
              Is it possible at all to do this comfortably?
              Or it would require to import all color swatches, and types of lines, the first document,  to others ...
