5 Replies Latest reply on Aug 8, 2013 11:36 AM by Alysson_Andrade
    [JS][CS6] ParagraphStyles to XML Tags
    Alysson_Andrade
      Hello!
      I need to create a XML structure based on Paragraph Styles of the entire document.
      I'm trying to create this structure:
      <Root>
      <hlhead>
      <hlhead>Example Paragraph</hlhead>
      <hlbullet>Bullet Paragraph 1</hlbullet>
      <hlbullet>Bullet Paragraph 2</hlbullet>
      So on...
      </hlhead>
      So on...
      </Root>
      Notes:
      - The tags needs to be different from paragraph style, so I'm reading the name of style to apply/create the tag.
      - The paragraph needs to be linked to tag too, for future XML import.
      Here's a example code of I'm trying to do:
      for(var i=0; i<=myPageItems.length; i++) { // Loop for the all document items
           var myTextFrame = myPageItems[i];
           if(myTextFrame instanceof TextFrame){ // Works on textframes only
                 var myParagraphs = myTextFrame.paragraphs; // Get the textframe paragraphs
                 for(var j=0; j<myParagraphs.length; j++) { // Loop for textframe paragraphs
                     // Debug
                     myParagraphs[j].select();
                     alert("Item: "+ myPageItems[i] +"\n"
                          + "Paragraphs: "+ myParagraphs.length +"\n"
                          + "ParagraphStyle: "+ myParagraphs[j].appliedParagraphStyle.name +"\n"
                          + "Text: "+ myParagraphs[j].contents +"\n"
                          + "xmlElem: "+ xmlElem +"\n"
                     // EndDebug
                     if(myParagraphs[j].appliedParagraphStyle.name == "3A hl head"){ // Check for ParagraphStyle
                          var xmlBody = xmlRoot.xmlElements.add({markupTag:"hlhead"}); // Add the parent element
                          var xmlElem = myParagraphs[j].markup( xmlBody.xmlElements.add({markupTag:"hlhead"}) ); // <- Error
                          //xmlElem.contents = myParagraphs[j].contents; // Put the content, but without links... unused
                     else if(myParagraphs[j].appliedParagraphStyle.name == "3D hl bullet"){
                          myParagraphs[j].markup( xmlBody.xmlElements.add({markupTag:"hlbullet"}) );
                     // Another else ifs
      I'm getting error in this part:
      Apparently the error is in "myParagraphs[j].markup" (because it "works" if removed), but the Paragraph Object have the markup method... I guess.
      What do I need to do?
      Can anybody help me on this, please?
      Thanks!
        • 1. Re: [JS][CS6] ParagraphStyles to XML Tags
          Techi Panda Level 2
          Hi
          the workflow is something like this
          1. Create your won XML tags via script or import tags
          2. Map your styles to tags to create XML
          var myDocument= app.activeDocument;
          myDocument.xmlTags.add("custom_tag");
          myDocument.xmlExportMaps.add(myDocument.paragraphStyles.item('para_style_name'),myDocument .xmlTags.item('custom_tag'));
          myDocument.mapStylesToXMLTags();
          Thank you
          arul
          http://in.linkedin.com/pub/arul-raja/14/672/681
          • 2. Re: [JS][CS6] ParagraphStyles to XML Tags
            Vamitul Level 4
            Teci solution is more elegant/efficient etc.
            but to fix yours:
            var xmlElem = myParagraphs[j].markup( xmlBody) );
            • 3. Re: [JS][CS6] ParagraphStyles to XML Tags
              Alysson_Andrade Level 1
              @Vamitul
              Hmm, I didn't understand...
              .markup( xmlBody) )  ?
              • 4. Re: [JS][CS6] ParagraphStyles to XML Tags
                Hi Techi,
                Thanks, it's too efficient and elegant as Vamitul said.
                But in my case, I need to make a specific structure, with specific parents, etc...
                I found this topics:
                http://forums.adobe.com/message/2879929#2879929
                http://forums.adobe.com/message/1113890#1113890
                They're saying the paragraph needs to be marked with the parent story/textframe.
                So, I tried this:
                var xmlParent = myParagraphs[j].parent.markup(xmlRoot.xmlElements.add({markupTag:"highlighthead"}));
                var xmlElem = myParagraphs[j].markup(xmlParent.add({markupTag:"highlighthead"}));
                But no result...
                What I'm doing wrong?
                • 5. Re: [JS][CS6] ParagraphStyles to XML Tags
                  Sorry for my... triple post, haha.
                  Yay, I did it!
                  Here's the code for future references:
                  #target indesign
                  myDoc = app.activeDocument;
                  myPageItems = myDoc.allPageItems;
                  xmlRoot = myDoc.xmlElements.item("Root");
                  createXML();
                  function createXML() {
                                                          // Debug
        + "parent: "+ myParagraphs[j].parent +"\n"
                                                          // EndDebug
                                                          selection = app.selection[0];
        xmlRoot.xmlElements.add({markupTag:"hlhead", xmlContent:selection});
        myParagraphs[j].parent.markup( xmlRoot.xmlElements.add({markupTag:"hlhead"}) );
        xmlRoot.xmlElements.add({markupTag:"hlbullet", xmlContent:selection});
                                                          else if(myParagraphs[j].appliedParagraphStyle.name == "3D hl bullet(last)")
        xmlRoot.xmlElements.add({markupTag:"hlbulletlast", xmlContent:selection});
                                                          // So on...
                  Thanks!
                  PS: My first js code!
