Hi All,
I am migrating a Joomla website to BC and have over 3000+ articles to add so I have imported a test of 190 articles into a particular category but I am experiencing an error with the import.
When importing all goes well with no error but when I visit the website the list view is fine but the details view displays blank on the front end of the website. When I visit the web app item in the admin of the site and hit the update button the web app item then displays correctly.
Hoping someone can help.
Don
I tried to replicate locally and the only scenario where items are not listed is when they are inactive because there is no release date set in the import file.
By the way do you see an "(inactive)" next to your newly imported items in admin?(I'm guessing not)
Please provide your site URL so we can check.
Kind Regards,
Alex
Sorry for the late response but somehow I did not see your message until I came back to search the forum again.
The site url is mnialive.businesscatalyst.com.
I've just attempted to import the files again and the same problem has happened again. I have attached a link to one of the CSV files that I imported below for you to review.
https://drive.google.com/file/d/0B18wZls_xkzRTUIyYW1SSXF1aXM/edit?usp=sharing
Thanks in advance for you help.
Don
Hi there!
How are you importing a joomla site to BC
I have a site with 700 pages I need to do the same..
about 12 different categories and just a bunch of detail pages for products.
they want to turn it into an ecommerce site,
but i can't find a decent way of getting the data into bc or even output to a csv file to manually edit
any help you have would be appreciated!!
Hey Dean,
Plenty of plugins for joomla to export the info in csv etc. You can just copy the info into the correct format on the web app import.
Hi ya joomla 2.5 and above seems to have good csv export..
unfortunately this site is joomla 1.5
can you give me heads up on what tools u were using to export it? if i do
update the joomla site.
I duno how much or safe will be to update it.
thanks for reply
On Sun, Feb 15, 2015 at 12:37 AM, Liam Dilley <forums_noreply@adobe.com>
I got around that problem by using a tool called Navicat Premium Essentials. It will connect to your websites database and let you choose what tables and field you want to export out in CSV or Excel format. I use a Mac so I bought mine from the Mac App Store but you can download a trial version to connect to your database and then download your data.
http://www.navicat.com/products/navicat-premium
You may find that your server blocks access to Navicat but most servers I have connected to have let me use it in the past. If that happens then my suggestion would be to export your websites SQL database onto your desktop and then use Navicat with a local installation of Joomla to get the files.
Hope this helps.
Paying $799 usd is not a 'way around' any problem.
That is a very very expensive solution to the problem.
thanks for your input.
I will have a look at it, but there are several mysql tools that connect to databases well under the $100 mark.
This must do something really special.
So i'll take a peak, but it's wayyyy out of my price range for solutions.
thanks again.
I think you looked at the wrong options as I only paid about £25 for the solution that I needed. There are definitely cheaper options available to you.
Hosting, PCI compliance, Server maintenance, system maintenance, Security certificate, features, support Plus the features.... Start buying those all separately or running the support yourself etc... it all adds up and equates to time you have to spend in other solutions. Can cost you more in many cases
