3 Replies Latest reply on Aug 9, 2013 4:16 PM by YOSHIOKA Ume
    How to change the position of an element with code?
    chino_10
      Hi! I'm doing a drag & drop, in this case they send me a question and 4 answer options, the user has to drag the correct answer into a box, then the question change and a new 4 answers appears. But i cant' "reset" the position of my draggable elements for the next question.
      Please help me =)
      i'm using this code :
      yepnope(
          nope:[
            'js/jquery-ui-1.9.2.custom.min.js',
            'js/jquery.ui.touch-punch.min.js',
            'css/jquery-ui-1.9.2.custom.min.css'
          complete: init
      function init() {
                var stage = sym.$("Stage");
                var Rect1 = sym.$("Rect1");
                var Rect2 = sym.$("Rect2");
                var Rect3 = sym.$("Rect3");
                var Rect4 = sym.$("Rect4");
                Rect1.html("1");
                Rect2.html("2");
                Rect3.html("3");
                Rect4.html("4");
                Rect1.css("text-align", "center");
                Rect2.css("text-align", "center");
                Rect3.css("text-align", "center");
                Rect4.css("text-align", "center");
                Rect1.draggable({ containment: stage});
                Rect2.draggable({ containment: stage });
                Rect3.draggable({ containment: stage });
                Rect4.draggable({ containment: stage });
                Rect1.draggable( "option", "revert", "invalid");// If the user doesn't drag the correct answer, it return's to original position, but if he answer right, the draggable have to snap to the box.
                Rect2.draggable( "option", "revert", "invalid");
                Rect3.draggable( "option", "revert", "invalid");
                Rect4.draggable( "option", "revert", "invalid");
         // droppable box
                var dropCase1 = sym.$("dropCase1");
                dropCase1.css("position", "absolute");
                dropCase1.droppable({
                                    accept: caso, // my var "caso" is changing according the current question. for that i use a switch /case statement.
                          drop: function(event, ui) {
                                    console.log("bien");
        • 1. Re: How to change the position of an element with code?
          YOSHIOKA Ume Level 3
          Hi, chino_10.
          I tried!
          1.set 4 rects & dropCase.
          2. add code
          var correctID = sym.$("Rect1").attr("id");  //correct rect
          function init(){
            sym.$("dropCase").droppable({
              accept:".button",
              tolerance: "fit",
              drop:function(evt, ui){
                if(ui.draggable.attr("id")==correctID){
                  console.log("correct");
                  ui.draggable({revert:false}); //turn off revert flag
                }else{
                  console.log("incorrect");
            $(".button").draggable({revert:true});
          //load jQuery-ui from CDN & init
          yepnope({
           nope:"http://ajax.googleapis.com/ajax/libs/jqueryui/1.10.3/jquery-ui.min.js",
           complete:init
          hth. Ume.
          • 2. Re: How to change the position of an element with code?
            chino_10 Level 1
            Thank's that help's me a lot!!
            Now i have other problem and i hope you can help me
            I have 10 draggable items and i have to drag 6 of them into a box.
            The user can drag 1 to 10 items into the box, then he click's a check button, if he drag 6 then the answer is correct, if he drags any other number the answer is incorrect. Again my problem is when i have to "reset" the game..
            Please please help me guys I'm stuck.
            Here is my code
            // This code is inside a trigger in a symbol timeline
            yepnope(
                nope:[
                complete: init
            function init() {
                       var car1 = sym.$("car1");
                      var car2 = sym.$("car2");
                      var car3 = sym.$("car3");
                      var car4 = sym.$("car4");
                      var car5 = sym.$("car5");
                      var car6 = sym.$("car6");
                      var car7 = sym.$("car7");
                      var car8 = sym.$("car8");
                      car1.draggable({ containment: stage });
                      car2.draggable({ containment: stage });
                      car3.draggable({ containment: stage });
                      car4.draggable({ containment: stage });
                      car5.draggable({ containment: stage });
                      car6.draggable({ containment: stage });
                      car7.draggable({ containment: stage });
                      car8.draggable({ containment: stage });
                                          accept: ".case1",                                             // all my draggable items (cars) have the same class ".case1"
                                          activeClass: 'ui-state-hover',
                                          hoverClass: 'ui-state-active',
                              switch (caso){                                           //i use this var "caso" to difference the dragable item, onClik
                                                              case ".case1":
        car1.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case2":
        car2.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case3":
        car3.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case4":
        car4.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case5":
        car5.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case6":
        car6.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case7":
        car7.draggable( "option", "disabled", true );
                                                              break;
                                                              case ".case8":
        car8.draggable( "option", "disabled", true );
                                                              break;
                                                    counter++;                // this counts the number of items the user drag into the box
            //**************************** This is my "check button" code:**********************
            if (counter == 6){
                 console.log ("good")
            } else {
                 counter = 0;
                 /// here i have to "reset" my game position.
            • 3. Re: How to change the position of an element with code?
              Hi.
              hmm... use $(elem).data() to recording base position of element.
              spadework:
              1.add class ".case1" to draggable elements.
              2.add class ".correct" to correct elements. so correct elem has two classes "case1 correct".
              code is like this.
              //record the pos data to .case1-element.
              $(".case1").each(function(index,elm){
                var $hdl = $(elm);
                $hdl.data("basePos",{top:$hdl.css("top"),left:$hdl.css("left")});
              //get the pos data & animate.
              sym.$("checkButton").click(function(){
                  var $hdl = $(elm);
                  $hdl.animate($hdl.data("basePos"));
              function init(){
                  accept:".correct",  //accept only ".correct" elem.
                  tolerance: "fit",
                      ui.draggable.draggable({revert:false}); //turn off revert flag
                $(".case1").draggable({revert:true});
              yepnope({
               complete:init
              hth. Ume.
