0 Replies Latest reply on Aug 7, 2013 8:58 PM by derrekteng
    any way to convert xfl or fla to custom format?
    derrekteng
      the fla format is not open source. but the xfl is.
      the DOMDocumtent.xml has this kind of format:
      <timelines>
                <DOMTimeline name="scene 1" currentFrame="22">
                     <layers>
                          <DOMLayer name="layer 2" color="#9933CC" current="true" isSelected="true">
                               <frames>
                                    <DOMFrame index="0" duration="22" tweenType="motion" motionTweenSnap="true" keyMode="22017">
                                         <elements>
                                              <DOMSymbolInstance libraryItemName="symbol 1" symbolType="graphic" loop="loop">
                                                   <matrix>
                                                        <Matrix tx="43.3" ty="61"/>
                                                   </matrix>
                                                   <transformationPoint>
                                                        <Point x="278" y="144"/>
                                                   </transformationPoint>
                                              </DOMSymbolInstance>
                                         </elements>
                                    </DOMFrame>
                                    <DOMFrame index="22" keyMode="9728">
                                         <elements>
                                                   <matrix>
                                                        <Matrix a="0.162002563476563" b="-0.0935211181640625" c="0.159713745117188" d="0.276641845703125" tx="253.25" ty="191.15"/>
                                                   </matrix>
                                                       <Point x="278.05" y="144.05"/>
                                         </elements>
                                    </DOMFrame>
                               </frames>
                          </DOMLayer>
      it has all the info about this flash file. but, what i want is like kind of this:
      <key>fengmo</key>         // this is the name of scene or a symbol
      <dict>
      <key>frameRate</key>
      <real>20</real>
      <key>frameCount</key>
      <real>85</real>
      <key>layerCount</key>
      <real>10</real>
      <key>layerDict</key>
      <dict>
      <key>0</key> // this is the first layer
      <dict>
      <real>85</real>
      <key>keyFrameCount</key>
      <real>5</real>
      <key>keyFrameDict</key>
      <dict>
      <key>0</key>  // this is the first layer's first keyframe
      <dict>
      <key>startFrame</key>
      <real>0</real>
      <key>elementNum</key>
      <real>0</real>
      <key>elementDict</key>
      <dict/>// this keyframe has no element
      </dict>
      <key>1</key>
      <dict>
      <real>71</real>
      <real>1</real>
      <dict>
      <key>0</key>
      <dict>
      <key>type</key>
      <real>1</real>
      <key>libName</key>
      <string>l4_feng</string>
      <key>instanceName</key>
      <string></string>
      <key>depth</key>
      <real>1</real>
      <key>position</key>
      <string>{87,-10}</string>
      <key>transformationPoint</key>
      <string>{0,0}</string>
      <key>scaleValue</key>
      <string>{1,1}</string>
      <key>rotation</key>
      <real>0</real>
      <key>skewValue</key>
      <key>alpha</key>
      <real>100</real>
      </dict>
      </dict>
      <key>motionEnd
      FrameIndex</key>
      <real>73</real>
      </dict>
      <key>2</key>
      <dict>
      <real>73</real>
      <real>1</real>
      <dict>
      <key>0</key>
      <dict>
      <key>type</key>
      <real>1</real>
      <key>libName</key>
      <string></string>
      <key>depth</key>
      <real>1</real>
      <key>position</key>
      <string>{89,-10}</string>
      <string>{1.1730804443359375
      ,1.1730804443359375}</string>
      <key>rotation</key>
      <real>0</real>
      <key>alpha</key>
      <real>100</real>
      </dict>
      </dict>
      <key>motionEnd
      FrameIndex</key>
      <real>75</real>
      </dict>
      as there is no direct method to save the xfl as the format of what I want,
      then, I have following questions:
      1 how can I convert the matrix info to the info of (position, transformationPoint, scaleValue, skewValue, rotation).
      2 I find that in the flash software, I can export xml motion, it's format is like this:
      <Motion duration="30" xmlns="fl.motion.*" xmlns:geom="flash.geom.*" xmlns:filters="flash.filters.*">
                <source>
                          <Source frameRate="24" x="102" y="93" scaleX="0.18" scaleY="0.215" rotation="0" elementType="graphic" symbolName="zhiyingyong">
                                    <dimensions>
                                              <geom:Rectangle left="0" top="0" width="556" height="288"/>
                                    </dimensions>
                                              <geom:Point x="0.5" y="0.5"/>
                          </Source>
                </source>
                <Keyframe index="0" tweenSnap="true">
                          <tweens>
                                    <SimpleEase ease="0"/>
                          </tweens>
                </Keyframe>
                <Keyframe index="11" tweenSnap="true" x="126" y="189" scaleX="1.4166666666666667" scaleY="1.4837209302325582">
                          <tweens>
                          </tweens>
                </Keyframe>
                <Keyframe index="22" tweenSnap="true" x="321.95" y="10" rotation="-30">
                          <tweens>
                          </tweens>
                </Keyframe>
                <Keyframe index="29" rotation="-75"/>
      </Motion>
      it's kind of what I want, however, the command can just be applyed to one (scene or symbol)'s one layer, it can not export all layers of all (scene & symbol)'s motion info to one file. it just can not export the motion just as what xfl is.
      so the question is : can xfl save as the format of "export xml motion" is?
      3. is there any way to config flash software's xfl format when it save?
      thanks! waiting for your reply.
