2 Replies Latest reply: Aug 8, 2013 1:32 PM by Martino77 RSS
    Is it possible to have a transparent stage-background?
    Martino77 Community Member
      When I change the color of the stage into transparent, the stage remains to have color.
      I found other people having the same problem.
      Am I doing something wrong here, or isn't it possible to have a transparent stage?
        • 1. Re: Is it possible to have a transparent stage-background?
          robboerman Community Member
          yea i noticed that, can you maby share the project so we can see what is causing the problem and how to fix it?
          it will help other people to
          • 2. Re: Is it possible to have a transparent stage-background?
            Hi Rob, this morning I tried a lot and I was convinced it wasn't possible to have a transparent background, but at least white.
            Now I did another test and it looks like I was mistaken. If I change the body-background manually to green, and set the stage to have a transparent background, edge shows the stage-background as green, so transparency seem to work fine.
            I guess the reason I was confused was that I'm so used to Adobe products showing the pattern when a background is transparent, like this:
            Instead, EA shows this for a transparent stage:
            Well, anyway, I obviously was mistaken. Adobe seems to show the real background-color (behind the transparent stage), so I have to get used to it, but it could be very handy!
            I'm glad it works Thanks for your help!
