1 Reply Latest reply on Aug 8, 2013 1:21 PM by petergaraway
    New Nvidia Graphics Cards for Premiere GPU Acceleration
    chriso77
      Hi! I'm looking for a new laptop. Under the list of the cards usesd for GPU Acceleration in Premiere (http://www.adobe.com/products/premiere/tech-specs.edu.html), none of the new GTX 700m's are listed. Is the list of acceptable GPUs out of date and the 700s do work, or do the 700s really not work? Thanks!
        • 1. Re: New Nvidia Graphics Cards for Premiere GPU Acceleration
          petergaraway Adobe Employee
          Hi Chris,
          For Premiere Pro CC we made some chnages to our GPU support. See this post by Al Mooney.
          Also, some customers may be aware that in the past there was a not-so-secret way of enabling non-supported GPUs by the ‘hacking’ or removal of a text file. This is no longer necessary in Premiere Pro CC. As long as you have a reasonably modern card with at least 1GB of VRAM, you will still be able to enable that card in the Project Settings dialog. A warning message will appear letting you know that your card has not been certified by Adobe, but once that dialog is clicked through you can use your GPU. The team does try to certify as many GPUs as possible, but we can’t test everything, so this is a way to let you decide if you’re happy using an untested configuration.
          http://blogs.adobe.com/premierepro/2013/06/adobe-premiere-pro-cc-and-gpu-support.html
          Peter Garaway
          Adobe
          Premiere Pro
