9 Replies Latest reply on Oct 10, 2007 9:47 AM by C-Rock
    getUrl
    janst
      Why can't I use ../ for getUrl?
      I am very frustrated with this... I want to test my site locally without having to change all the links...
      Thank you!
        • 1. Re: getUrl
          Level 7
          janst,
          You should be able to. I use relative paths all the time.
          > on (release) {
          > getURL(../pages/citicard.html);
          Your URL needs to be a string, so wrap it in quotes. Let me know if
          that does it for you.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: getUrl
            janst Level 1
            I know this is a very simple question, but does anyone know what I need to do here? Do I have to type in the full local filepath to test and then go through every swf and change all the links to the final destination file path?
            Is there a quicker way to test?
            Thanks...
            I am a bit overwhelmed with work right now...
            • 3. Re: getUrl
              C-Rock Level 2
              how about:
              getURL("./pages/citicard.html", "_blank");
              • 4. Re: getUrl
                janst Level 1
                I guess I can just dump everything into one folder so I don't have to use ../ until I find out the ActionScript that replaces the../ code... I like having neat folders for everything ... I like organization so I can see everything clearly... I guess I'll have it live in chaos
                So frustrated and have very little time...
                • 5. Re: getUrl
                  janst Level 1
                  The problem is that when I use ../ I get an error from Flash 8.
                  • 6. Re: getUrl
                    C-Rock Level 2
                    you were missing the quotes and the blank statement.... that's more important than the two dots or one dot. you can use either or.
                    • 7. Re: getUrl
                      janst Level 1
                      I still get the error using the blank statement... The error is on the ../
                      • 8. Re: getUrl
                        janst Level 1
                        quote:
                        It was the "quotes".... I should have just looked at one of my other working websites... For some reason, I was blanking on the quotes...
                        It's going to be a long day!
                        Thank you so much for looking at this for me. I REALLY appreciate it!!!
                        • 9. Re: getUrl
                          C-Rock Level 2
                          you opening a file like an image or and html page?
                          if you are typing getURL in the actons panel look at it's requirements. you must have a string of what to open then how, blank, parent or whatever page.
                          also looking in the help docs is easy. highlight getURL and hit F1 for help.
