4 Replies Latest reply on Oct 7, 2007 6:47 PM by serg2049
    Blur effect using actionscript
    serg2049
      How can I make a blur effect using actionscript, not the built-in effect for which I have to use a tween?
      Any codes you can give me or links to tutorials?
        • 1. Re: Blur effect using actionscript
          Level 7
          Search help files for new flash.filters.BlurFilter
          It show in steps how to set each filter using action script, including all the
          parameters, like size
          Best Regards
          Urami
          "Never play Leap-Frog with a Unicorn."
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: Blur effect using actionscript
            serg2049 Level 1
            Thanks I'll check it out,
            • 3. Re: Blur effect using actionscript
              serg2049 Level 1
              Ok, Using flash help file sI did this:
              import flash.filters.BlurFilter;
              var rect:MovieClip = createRectangle(100, 100, 0x003366, "BlurFilterExample");
              var blurX:Number = 30;
              var blurY:Number = 30;
              var quality:Number = 3;
              var filter:BlurFilter = new BlurFilter(blurX, blurY, quality);
              var filterArray:Array = new Array();
              filterArray.push(filter);
              mymovie_mx.filters = filterArray;
              It did work, but I have 2 problems with this, one I need it to go from 100% blur to 30%blur.
              But my biggest problem is, part of the code I'm using in the animation is actionscript 1, and the above solution is actionscript 2.
              Can anyone give me an actionscript 1 solution?
              • 4. Re: Blur effect using actionscript
                serg2049 Level 1
                ANYONE?
                If it's too much to ask to post the code in actionscript 1 a link will do, please?
