3 Replies Latest reply on Aug 11, 2013 2:29 AM by pwillener
    Shared Object Location Flash Player 11
    flashGordon
      Where is the location of Shared Objects for Flash Player 11 in Vista?
        • 1. Re: Shared Object Location Flash Player 11
          pwillener Level 8
          Either in %appdata%\Adobe\Flash Player or %appdata%\Macromedia\Flash Player
          • 2. Re: Shared Object Location Flash Player 11
            flashGordon Level 1
            Thanks for your reply.
            I can find those directories as you have suggested but with directory  roaming
            AppData\Roaming\Adobe.....
            AppData\Roaming\Macromedia\Flash Player\#SharedObjects...
            In Flash Player 10, it is stored in :
            But when I installed Flash Player 11 and went to the site I want data  to be stored, it wasn't there (I expected the data to be stored in this directory as it did using Flash player 10) . I am just wondering if Flash Player 10 and 11 use the same folder.
            I need to know because I want to make a backup of the data , so that I can manually put them back when installing new flashplayer.
            Flash Player 11 erases  old data upon installation.
            • 3. Re: Shared Object Location Flash Player 11
              pwillener Level 8
              It's the same location for player 10 and 11, but the path is different for Windows versions, so it's best to use the %APPDATA% environment variable to go there.
